Which you after? I want an upgrade on the standards n all. Not bothered about HID, even if it's just projector halogens. Not sure where or what to look for.
You need to rewire and code if you have the 5dr A3 (sportback) but if you have the 3dr A3 (hatchback) then it's simply a matter of plug and play. Good luck
As I see from your avatar, it is 3dr. You don't need to change or do anything, It's plug&play and must do for pre facelifts
But pay attention to the "clips" of the lights, There are two at the outsides and one at the inside, and they are a bit hard to remove.
