Face lift lights
Nathan Sanders
I want face lift lights in my s3 8p 2007 do I need anything for this to happen or is it plug and play ?
Which you after? I want an upgrade on the standards n all. Not bothered about HID, even if it's just projector halogens. Not sure where or what to look for.
There's a thread just below about them that has a video of how to install.
Needs Rewire and coding but doesn't look too hard
You need to rewire and code if you have the 5dr A3 (sportback) but if you have the 3dr A3 (hatchback) then it's simply a matter of plug and play. Good luck
As I see from your avatar, it is 3dr. You don't need to change or do anything, It's plug&play and must do for pre facelifts :)
But pay attention to the "clips" of the lights, There are two at the outsides and one at the inside, and they are a bit hard to remove.
Can be done in 30 mins.
worth taking the time while the lights are off to give it a good clean and polish behind there, it will be grubby !
most of the bulbs are a straight swap ... there is one set to be changed ... though memory escapes me which :blink:
9
904
750
632
