a4 boot not opening
bazdono
Hi all I'm new here just wondered if anyone available in stockton on tees my roof needs resetting and the flaming boot won't unlock with fob or key have tried the override switch nothing opening it yet warning light says boot open any help gratefully accepted
You say the roof is not working, that is on a cabriolet yea? And you say the boot is "open" on the DIS? If so, the 2 are connected. If the car thinks the boot is open the roof will not go down.
Sounds similar to here - http://www.audi-sport.net/xf/thread...lock-and-roof-not-working-please-help.267104/ - I'm not sure if there was ever a solution, but a vcds scan will def help.
If you need a vcds scan and don't have the cable yourself, check on the VCDS map for your nearest member with a cable. http://www.audi-sport.net/xf/pages/VCDS-Map/
