I recently had the EML come on, ran VAG-COM and it confirmed the following codes. Keen to check I am thinking correctly and what I need to rectify the problems.
2 Faults Found:
008584 - Bank 1; System too Rich at Idle
P2188 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 53716 km
Time Indication: 0
Date: 2016.03.23
Time: 11:19:45
Freeze Frame:
RPM: 762 /min
Load: 23.9 %
Speed: 0.0 km/h
Temperature: 75.0°C
Temperature: 18.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
Air Flow Meter (Clean or replace, Air filter, (Clean or replace). Anything else to consider or check?
005425 - Camshaft Timing Adjustment
P1531 - 004 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 21
Reset counter: 255
Mileage: 53896 km
Time Indication: 0
Date: 2016.04.02
Time: 19:14:41
Freeze Frame:
RPM: 1488 /min
Load: 14.9 %
Speed: 35.0 km/h
Temperature: 47.0°C
Temperature: 22.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.097 V
Replace N205 - Camshaft Adjustment Valve, Camshaft Position Senor. Anything else to consider or check?
Keen to get this sorted over the weekend, any help or advice would be much appreciated.
2 Faults Found:
P2188 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 53716 km
Time Indication: 0
Date: 2016.03.23
Time: 11:19:45
Freeze Frame:
RPM: 762 /min
Load: 23.9 %
Speed: 0.0 km/h
Temperature: 75.0°C
Temperature: 18.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 255
Mileage: 53896 km
Time Indication: 0
Date: 2016.04.02
Time: 19:14:41
Freeze Frame:
RPM: 1488 /min
Load: 14.9 %
Speed: 35.0 km/h
Temperature: 47.0°C
Temperature: 22.0°C
Voltage: 14.097 V
