Gavin thyvhhh
- Joined
- Mar 26, 2016
- Messages
- 58
- Reaction score
- 5
- Points
- 8
Hi been offered two recently rebuilt engines
First one
Stage 2 mapped at 19psi 346.1bhp 347.7lb/ft tq.
Engine..
Apx fully rebuilt head, new stem seals etc
Genuine audi oil pump,
Oem timing belt kit,
Bam block
Dm forged rods,
Honed and bored and fitted with oem piston rings,
Oem timing belt kit and new tensioner fitted approx 8k miles ago.
New oil pickup pipe
Currently at 160k on the car. 16k since the engine was rebuilt. Has been serviced every 3k miles with out an extra mile done.
£1300 plus
You get the engine, all aux pump belts, inlet mani,
Im throwing in the oem dualmass flywheel and pressure plate (7k) miles and the 630cc injectors if the price is met
£1300
Or
*New Big End Bearings
*New Water Pump
*Every Single Gasket and Seal
*New Head Bolts
*Skimmed head with new valve stems
*All New Exhaust valves
*All New Inlet Valves
*All New Piston Rings
*Fully Cleaned and Painted Block
*Oil & Filter changed then changed again at 200 miles
*New Cam Belts & ALL Pullys Inc: Hydraulic Pully
*New Oil Pump
*New Oil Pick up chain
*New Oil Level Sender
*New Oil Pressure Sensor
*New Iridium Spark Plugs
No forged rods tho but only 900 miles done
All for £800
Which one would you pick?
Am looking to keep car for a while and when all done would like to get close to 400bhp
Any help appreciated
First one
Engine..
Bam block
Dm forged rods,
New oil pickup pipe
£1300 plus
£1300
Or
*New Water Pump
*New Head Bolts
*New Oil Pump
All for £800
