- Joined
- May 7, 2016
- Messages
- 1,187
- Reaction score
- 222
- Points
- 63
Hi,
I have a A3 2006 2.0 170 TDI Quattro ( BMN ) - driving yesterday and after 2 minutes it cut out. I've read similar storeis of injectors shorting out causing similar symptoms.
Is the recall still on for the A3's? Also I got a VAGCOM read of the erros and it is pointing at the Camshaft sensor, the symptoms also match up to being a faults Camshaft sensor
The car behaves as if it's just about to start but won't
All guidance will be appreciated, thiis all happened at about 18:27 timestamp, the vehicle was not in use before this so not sure why the Lambda sensor is showing an error
4 Faults Found:
000305 - Oxygen (Lambda) Sensor B1 S1
P0131 - 008 - Signal too Low - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 164128 km
Time Indication: 0
Date: 2016.06.20
Time: 17:27:14
Freeze Frame:
RPM: 1728 /min
Torque: 0.0 Nm
Absolute Pres.: 1130.0 mbar
Voltage: 3.07 V
Bin. Bits: 00000001
Text: 784 C
Text: -0.04 V
012296 - Camshaft Position Sensor (G40)
P3008 - 006 - Signal Out of Range - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 6
Reset counter: 40
Mileage: 164296 km
Time Indication: 0
Date: 2016.06.21
Time: 18:27:31
Freeze Frame:
RPM: 896 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Steering Angle: -47.95°
Angle: 0.0 °
(no units): 1.0
Steering Angle: -12.73°
000833 - Camshaft Position Sensor (G40)
P0341 - 006 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 40
Mileage: 164296 km
Time Indication: 0
Date: 2016.06.21
Time: 18:28:18
Freeze Frame:
RPM: 224 /min
Torque: 152.0 Nm
Speed: 0.0 km/h
(no units): 2.0
Steering Angle: 0.00°
Angle: 0.0 °
(no units): 10.0
000801 - Engine Speed Sensor (G28)
P0321 - 006 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 164296 km
Time Indication: 0
Date: 2016.06.21
Time: 22:39:34
Freeze Frame:
RPM: 64 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Time: 0.02 s
Angle: 0.0 °
Bin. Bits: 00000000
Bin. Bits: 00000001
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 164128 km
Time Indication: 0
Date: 2016.06.20
Time: 17:27:14
Freeze Frame:
RPM: 1728 /min
Torque: 0.0 Nm
Voltage: 3.07 V
Bin. Bits: 00000001
Text: 784 C
Text: -0.04 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 40
Mileage: 164296 km
Time Indication: 0
Date: 2016.06.21
Time: 18:27:31
Freeze Frame:
RPM: 896 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Angle: 0.0 °
(no units): 1.0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 40
Mileage: 164296 km
Time Indication: 0
Date: 2016.06.21
Time: 18:28:18
Freeze Frame:
RPM: 224 /min
Torque: 152.0 Nm
Speed: 0.0 km/h
(no units): 2.0
Angle: 0.0 °
(no units): 10.0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 164296 km
Time Indication: 0
Date: 2016.06.21
Time: 22:39:34
Freeze Frame:
RPM: 64 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Time: 0.02 s
Angle: 0.0 °
Bin. Bits: 00000000
Bin. Bits: 00000001
