aftermarket aerial adapter connection help required if possible chaps.
Charlie Farley
Chilling out.
Staff member
Moderator
Age
61
At Home
I am about to do my new head unit retro fit but wanted to be clear on the aerial connection .
My old concert 2 head had the double fakra plug but my new alpine has normal iso plug as such my fitting kit came with the appropriate aerial adapter lead , connnects2 CT27AA14 , now that's a single fakra plug with a blue lead which I assume is to power the aerial booster, but i'm not 100% clear on where that blue wire should be connected.
the alpine has a blue/white wire ( Remote turn on) and a blue (power antenna ) wire but manual says not use these, so where do I hook up the blue wire if those are not correct.
any input would be very good this evening chaps.
rob
Wish I knew what the fakra you were talking about :tongueclosed:
Reactions: Charlie Farley
wish I did too steve.....someone must though.
I should have said , fakra to DIN , not ISO..but still has the blue lead that need connecting to something.
Have you tried it out with it disconnected?
Stereo blue wire is powered with stereo on so should be fine to connect
