Stupid clock question...
Peloton
Ok I feel a bit daft asking this but I'm stumped and beginning to think the button's knackered. How do you change the time on the clock? :uhm: All it says in the manual is that you use the left hand button in the dash cluster bit. Believe me, I've tried twisting, pressing, turning & pushing this damn button but all I get is the speed limiter thing & the test procedure.
Help! :sos: It's doing my head in!
Pull it to activate changing, pulling again gives hours thenminutes etc, then twist left or right to change the values
pull the stalk to activate it, then each further pulls will jump from hours/mins/day/month/year/all flashing/then set
once a segment is flashing, hours for instance - twisting the stalk left will reduce the value and twisting the stalk right, will increase the value of the flashing =)
If its the same as the A4 you pull it towards yourself an turn in the direction required.
Good stuff. It's been 5 minutes fast for as long as I've had it, which I could handle but 1hr & 5 mins is just too much to settle for.
Thanks :beerchug:
938
534
