A4 B7 3.0 Tdi not starting
Askelon04
41
Hi folks,
been lurking around this (and other audi forums for a few months now)
Unfortunately my lovely car cut out on me today and now will not start.
No MIL, no flashes coil, turning over fine just not firing.
Run VCDS but very much a newbie with it (only bought cable jsut afore christmas)
Did an auto scan and got the log file (Will post below)
Noticed there was nothing from the injection pump (41 - Diesel Pump) so tried to read that but got no response from controller when trying to connect. I am fearing this is the root of my problems.
Can anyone help from the information below?
Thanks in advance
Wayne
VIN: WAUZZZ8E15A499908 License Plate: DGxxVNB
Mileage: 210090km-130543mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E15A499908 Mileage: 210090km-130543miles
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 8E0 910 401 F HW: 8E0 907 401 AJ
Component: 3.0L V6TDI G000AG 0040
Revision: --H01--- Serial number:
Coding: 0011171
Shop #: WSC 00861 210 63874
VCID: 22401C60FDD35352FF-8076
3 Faults Found:
005491 - Left Engine Mount Solenoid Valve (N144)
P1573 - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 182
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 777 /min
Torque: 50.7 Nm
Speed: 0.0 km/h
Voltage: 13.98 V
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
012697 - Control Circuit for Intake Manifold Runner (Bank2)
P3199 - 002 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 17
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 777 /min
Torque: 42.9 Nm
Speed: 0.0 km/h
Voltage: 11.63 V
Duty Cycle: 84.8 %
Duty Cycle: 0.4 %
Duty Cycle: 80.9 %
004499 - Fuel Pressure Sensor (G247)
P1193 - 001 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 12.16 V
Pressure: 0.0 bar
Duty Cycle: 8.7 %
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0050
Revision: --H01--- Serial number: 4002937
Coding: 0000001
Shop #: WSC 06335 000 00000
VCID: 64CC5A78A7471D624D-8030
1 Fault Found:
18289 - Powertrain Data Bus: Missing Message
P1881 - 001 - Acceleration Request - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 209782 km
Time Indication: 0
Freeze Frame:
RPM: 768 /min
RPM: 352 /min
RPM: 96 /min
(no units): 7.0
(no units): 27.0
Temperature: 32.0°C
T.B. Angle: 3.5°
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
Component: ESP8 quattro H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004426
VCID: 27560D7496F1B67AA8-8072
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AL
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
VCID: 6BDE31441999521A0C-50C8
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 H
Component: int. Lastmodul ECE 0503
Coding: 00001
Shop #: WSC 06335
VCID: 3776DD34155126FA38-4A82
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M002P4EX
Coding: 0033622
VCID: 3B7EC1047A79029ADC-806E
Subsystem 1 - Serial number: 6332DRB4016BCBAE5
Subsystem 2 - Serial number: 6342DRB401724B28J
Subsystem 3 - Serial number: 6352ARB4004B3BEC.
Subsystem 4 - Serial number: 6362ARB40049D62AR
Subsystem 5 - Serial number: 63729RB4004FC6A5Z
Subsystem 6 - Serial number: 63829RB4004FC6D7+
4 Faults Found:
01221 - Crash Sensor Side Airbag; Driver Side (G179)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 185
Reset counter: 99
Time Indication: 0
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 8
Reset counter: 99
Time Indication: 0
01316 - ABS Control Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 R
Component: Lenksáulenmodul 0501
Coding: 01021
Shop #: WSC 00861
VCID: 4280BCE04E9373529F-4A82
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 950 S HW: 8E0 920 950 S
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0007401
Shop #: WSC 73249 020 01196
VCID: 3972DB0C7345308ACE-50C8
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0007401
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
Component: RNS-E HIGH EU H44 0650
Revision: 01S Serial number: AUZBZ7D0004203
Coding: 0321713
Shop #: WSC 00000 785 00200
VCID: 244C1A78E4C75D628D-50E6
10 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 33
Time Indication: 0
Date: 2014.03.21
Time: 13:30:01
Freeze Frame:
Mileage: 655350 km
Count: 112
Clock: 18:42
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 254
Reset counter: 34
Time Indication: 0
Date: 2015.02.26
Time: 18:14:29
Freeze Frame:
Mileage: 655350 km
Count: 1012
Clock: 15:44
02446 - Disk Drive Mechanical Malfunction
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 18
Reset counter: 34
Time Indication: 0
Date: 2016.06.16
Time: 14:54:49
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
Freeze Frame:
Fault Priority: 5
Fault Frequency: 17
Reset counter: 37
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 601
Clock: 17:19
00878 - Connection to Speaker Front Left
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 33
Time Indication: 15
00879 - Connection to Speaker Front Right
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 33
Time Indication: 15
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 248
Time Indication: 0
Date: 2016.02.07
Time: 20:09:21
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 248
Time Indication: 0
Date: 2016.12.01
Time: 18:45:25
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 6
Reset counter: 33
Time Indication: 15
02444 - Disk Drive Load / Eject Malfunction
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 1
Time Indication: 0
Date: 2013.08.10
Time: 11:31:59
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: 6BDE31441999521A0C-50AC
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BM
Component: Komfortgerát T3B 2431
Coding: 06875
Shop #: WSC 02736
VCID: 7DFA0F1C77EDCCAAA2-4A82
Subsystem 1 - Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
1 Fault Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0321713
10 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 33
Time Indication: 0
Date: 2014.03.21
Time: 13:30:01
Freeze Frame:
Mileage: 655350 km
Count: 112
Clock: 18:42
02261 - Data Medium
Freeze Frame:
Fault Priority: 5
Reset counter: 34
Time Indication: 0
Date: 2015.02.26
Time: 18:14:29
Freeze Frame:
Mileage: 655350 km
Count: 1012
Clock: 15:44
Freeze Frame:
Fault Priority: 5
Fault Frequency: 18
Reset counter: 34
Time Indication: 0
Date: 2016.06.16
Time: 14:54:49
Freeze Frame:
Fault Priority: 5
Fault Frequency: 17
Reset counter: 37
Time Indication: 15
Freeze Frame:
Mileage: 655350 km
Count: 601
Clock: 17:19
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 33
Time Indication: 15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 33
Time Indication: 15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 248
Time Indication: 0
Date: 2016.02.07
Time: 20:09:21
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 248
Time Indication: 0
Date: 2016.12.01
Time: 18:45:25
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 33
Time Indication: 15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 1
Time Indication: 0
Date: 2013.08.10
Time: 11:31:59
End-------------------------(Elapsed Time: 06:13)--------------------------
Your car does not have a diesel pump injection module 41. You need to look at the fault rel ?ated to the fuel pressure sensor. You have loads of faults on the car, probably mostly historic. I would clear all of the faults and see what comes back. If the fuel pressure sensor issue is still there check the connectors and wiring .
Does the car have a tuning box ? If so I would disconnect it and connect the fuel pressure sensor directly.
Reactions: Askelon04
Desertstorm,
Thank you for that, thats put my mind at ease regarding the pump. as I said still a newbie at this. Yes the car did have a DTUK box fitted, and that was the very first thing I removed completely and tried again to start. I will try again tomorrow for the sensor, is it possible to run the car (albeit i guess in 'limp mode') with sensor unplugged?
Thanks for you help, appreciate it
Got back to car this afternoon, cleared codes and rerun the auto scan, all engine faults now cleared. Checked fuse for pump (assuming this is for charge pump in the tank?) and thats fine.
There is a v6 tdi engine at work (scrap yard) so i'm going to have a look what condition that is in tomorrow and see if its the right one for parts,
other than that it's off to garage on monday :(
Coding: 0011171
Readiness: 0 0 0 1 1
Coding: 0004426
1 Fault Found:
00493 - ESP-Sensor Unit (G419)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x1222
Hex Value: 0x00FF
Hex Value: 0xFF5F
Hex Value: 0x06FF
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
53-10 - Supply Voltage Too Low - Intermittent
Coding: 0033622
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 186
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 99
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Time Indication: 0
Coding: 0007401
1 Fault Found:
00668 - Supply Voltage Terminal 30
Coding: 0007401
1 Fault Found:
Coding: 06875
Shop #: WSC 02736
1 Fault Found:
35-00 - -
Have you checked you have fuel supply? Maybe the pump belt has broken?
