Hello, What it the body control module linked to? I`ve just had a new wiper motor fitted as that became intermittent and failed. Changed the bonnet latches as the micro switches were failing and now I have a few other issues.
One being :
1 Fault Found:
4720 - Body Control Module (Central Electric 2)
U0141 00 [040] - No Communications
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 24
Then I have a load of issues following on which I guess is related to that?
5 Faults Found:
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 62906 km
Date: 2017.02.14
Time: 00:01:03
8304 - Databus
U1121 00 [008] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 35
Reset counter: 96
Date: 2017.02.04
Time: 10:56:50
16390 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 62906 km
Date: 2017.02.14
Time: 00:01:13
16401 - Tire Pressure Warning
C102D 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 75
Date: 2017.02.04
Time: 10:56:50
32928 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 96
Mileage: 63023 km
Date: 2017.02.21
Time: 07:48:42
and does this mean I need a new alternator?
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 19 09 2013 C0345168
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051029893
1 Fault Found:
8531970 - Quiescent Current
U1406 00 [008] - Too High
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 95
Mileage: 62825 km
Date: 2017.02.11
Time: 14:35:54
Supply voltage: Terminal 30: 11.8 V
Terminal 15: OFF
One being :
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 24
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 62906 km
Date: 2017.02.14
Time: 00:01:03
8304 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 35
Reset counter: 96
Date: 2017.02.04
Time: 10:56:50
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 62906 km
Date: 2017.02.14
Time: 00:01:13
C102D 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 75
Date: 2017.02.04
Time: 10:56:50
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 96
Mileage: 63023 km
Date: 2017.02.21
Time: 07:48:42
Alternator:
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 95
Mileage: 62825 km
Date: 2017.02.11
Time: 14:35:54
Terminal 15: OFF
