Unfixing Emission Recall
SL11CKK
Barking & London
Anybody know of anyone who can flash ecu back to how it was before the emission recall.
Obviously Audi won't undo it therefore I wont even bother with asking them.
I've dropped an email to Darkside and they want the same money for remapping it.
To be honest I don't want to remap it as I'm more than happy with the power I have on stock.
Surely someone could spare a few minutes for flashing a stock map on. not like they loosing anything. Just drop em £20 for their time.
MRC usually keep the map on file and only charge the time to put it back on. I'm sure dark side would do the same?
What the reason for this?
In my case I feel it seems more juicy, but whats annoying me more is that its doing more and more dpf regens.
Also i'm noticing flat spots, however that could be just me
I've been hesitant about getting the fix done after seeing stories of people having EGR issues. It makes me wonder how "tried and tested" emissions fix really is?
I can only comment on mine which is the 177bhp Manual and one thing Im happy is not happening on mine is the pinking a lot of other marques are experiencing after the recall.
Remap to Stage 1 , you'll never look back .
I was thinking about that, but I sort of like having my DPF in place and don't want to wear it out quicker.
I've read that if I get rid of the DPF the smell coming from the exhaust becomes very strong.
You can keep dpf operational if you wish , definitely get the egr out .
I am also looking to have my EGR deleted/blanked but don't want to get rid of my DPF.
Found this statement on DarksideDevlopments site: ''The EGR Valve should NOT be removed on vehicles that still have the DPF Filter in place, doing so may block the DPF as the EGR Valve operation is a prerequisite for DPF Regeneration''
So would you advise if deleting EGR, you also remove the DPF? Anyone still have there DPF but removed EGR?
I think your are right when it comes to these engines. Usually on other engines codes you can do what is suggested and delete the EGR.
So I think I will still be on the lookout for the stock map before the Emission recall.
So far everyone I have contacted says I should remap and also they do not have any stock maps for my ecu on their database.
But I really don't want to go the remap route.
On a similar topic, the wife's a3 suffered an egr failure. So for the same price as replacement egr unit. I had egr blanked (coded out) and dpf gutted (but still in place for MOT) standard map put on, now gets upto 10mpg extra and drives perfect. Don't get confused thinking all remaps are for making your car a rocket.
Sent from my Note 4 using tapatalk
Reactions: SL11CKK
Still dont think that a map will give you MPG. MPG is calculated by fuel quantity injected and air flow across the MAF. Unless you can reduce them, or lean your fuel fixture out...you arent going to get any more MPG. Unless the timing maps are well out and not efficient at all.
Chances are, someone added a couple of % to the consumption values to make it show more.
Have you tried the guys at Superchips for a stock map, just a thought. :sos:
JG
Ive dropped an email to them, but I doubt they will be able to help. Im surprised nobody seems to be able to get stock map for it.
I've sort of sourced the actual map file, but to be honest have no idea on how to get it uploaded nor can I say if it is the pre-emission file.
They're worth a try mate, think it may be a case of nobody wants to give you the stock map, and would rather sell you a remap.
Another possibility maybe Rick at Unicorn Motor Developments.
I'm so glad I decided not to put my A5 in for the emission recall.
Good Luck in your quest to get this sorted, and keep us updated.
JG
So for a long overdue update!
I was getting at nowhere, went as far as buying another ecu however the issue became that its not as easy to clone the immobiliser data from my ecu to the doner ecu which doesnt have the emission update. Apparently more easier to do this on older ecus such as the EDC16 compared to mines which is EDC17.
I definitely was not going to entertain the idea of disabling the immobiliser to get around that as it then becomes a bodge job.
The other option is to use the software the dealer uses to flash back to the original which is what few people have done. So looking now into that option.
Keep us informed, would be interesting to see how you get on. Other than going to a dealer, how do you get your hands on the "dealer software" to flash it back?
If you want older software put on the ecu drop me a pm.
Together with vcds advance id page screen shot if you have it.
I normally have all revisions of vag software
Reactions: Mario
FINAL UPDATE:
I've finally reverted the sucker back to the firmware/software it was previous to the emission recall. This is confirmed as VCDS reports "2839" and whilst the emission firmware was in place it was reporting "9977"
Initially was booked in with Alex from VAG Car Coding who I found through Instagram and was pleasantly surprised he is a ASN site sponsor. He has access to all the flash files via VW/Audi and more importantly has the genuine tools and subscription and this attracted me to his service. He also knew exactly what I wanted to do.
However a close friend of mine responded back to me last minute after 2 weeks of waiting saying he knows how to revert back, but was truthful in saying he doesn't have genuine tool however has flashed plenty ecus and never once had an issue especially considering he was flashing stock firmware back in.
Fast forward the flash literally took less than a minute which normally takes 8-10 minutes. That in mind I was weary if the car would start however it did after I cycled ignition.
So to all those who want to undo/revert the emission recall definitely give Alex from VAG Car Coding a shout, he's based in North London.
Although I didn't go to him for the task, I will definitely be going to him to do other things.
A lot of tuners say to get it remapped, it wont take the issue at hand away because there are many parameters/setting within the flash file which VW/Audi changed. Obvious ones being DPF and EGR and how often they kick in.
Smaller things like the DIS telling you to change gears also been changed so you are "nagged" to jump to the highest gear.
Just hope the emission update has not done damage which may now be noticed now thats its back to "stock".
Maybe they remapped the emissions fixed file and left the EGR/DPF regen cycle in?
This is exactly what was happening to mine and I think the best way to go about it is put it back to the pre-emission software and then get it mapped again.
The reason I put it back to pre-emission software was because it was doing dpf regen more often and what was more frustrating was that I was hearing the fan kick in when i parked up after a long journey.
After putting it to standard I haven't heard the fan kicking in and also my mpg has gone back to normal so now I am seeing more of 49 - 53 mpg on the DIS compared to seeing 37 - 42 mpg on the DIS with the emission update.
Performance wise I feel that the lower end torque on 3rd gear is back so it doesn't feel like Im about to stall.
Regen cycle is mappable too
Hi Bobby,
Do you mean this can be altered to how frequent the regen cycles happen? How can this be done? I still have no update from Audi in regards to this. Not holding my breath either. Cheers.
Hi Bobby,
Yes but its done in tuning - you should log exhaust back pressure to engage how much back pressure you have.
How often do people see their cars regen and how do you know ?? I've had mine 3 years now and the only time ive seen the regen light on the dash is when I forced it via VCDS .. I do mainly only do motrorway journeys though which im guessing makes a difference, still find it odd ive never seen it do it though
Mine doesn't show anything when it's doing a cycle. Only know it is by the revs or when I'm using VAGDPF app.
Sent from my SM-N950F using Tapatalk
22
11
15
4K
