Ok Im not sure which problem you have solved.I have pfl sportback with pfl led. What means harness?
I have already solved the problem you are talking about.
Now I am looking for a solution to this problem. Inner lamps turn off when I close a car
Wysłane z mojego SM-G988B przy użyciu Tapatalka
Brake is straight connection. Should work without coding unless you have turned it off with coding.Hi all, I've wired up as per the attached diagram but my inner brake lights aren't working, all other lights in and outer are working as expected with no coding, going from pfl led to fl led. Can anyone shed some light on what may be wrong.
This wire diagram is correct so irrespective of what is going on with inner light Your brake light should work.Hi all, I've wired up as per the attached diagram but my inner brake lights aren't working, all other lights in and outer are working as expected with no coding, going from pfl led to fl led. Can anyone shed some light on what may be wrong.
Old outer connect pin 3 to new outer connector pin 3 for Brake is correctThis doesn't list a brake wire only a tail lamp wire which I'm assuming is the normal lights not the brake light? I've done no coding as of yet
Brake outside onlyLooking at this it looks like the inners don't have brake lights? Is this piece just a reflector?
Looks like everything is working as it around then, thanks for the helpBrake outside only
Not sure, dont think this part is even a reflector. Need to test it but definitely not light
Interestingly enough it's a clicking sound coming from the B and O amp under the passenger seat so it may be completely unrelated to the brake light outage, just odd it clicks when I push the brake pedal, only happens when the car is running too...Now I have a clicking sound coming from the box under the passenger seat when putting my foot on the brake and my left brake light is out... any ideas?
Sorry cant say why light has gone outNow I have a clicking sound coming from the box under the passenger seat when putting my foot on the brake and my left brake light is out... any ideas?
Again: Dont change too much in coding: for pfl led to fl led you can leave almost everything intact.
Changes are:
indicators outside to 127%
indicators inside remove from coding. (maybe we can also repin the ali express adapter and code this to 127% too, but not tested yet)
reverse light change to 127% or flickering will occor on rvc.
You might not notice but if you dont change indicator to 127% then someone else behind you might noticeAll sorted had a wire shorted to ground, vcds to the rescue with fault codes...
Also is this coding really required? I'm not noticing any issues with this not done???
I make and sell tail light change harness for A3 8V. I have never heard 31347 not working in 09 on any A3 8V, including Prefacelift and Facelift.Hi again, finally getting around to completing the coding but everytime I try to enter the security access code 31347 for the 09 Cent. Elect. module VCDS says:
Controller refused key! Error 00: Unknown (0x00)
Anyone know a working security code for this module in a 2016 pfl rs3?
Could it be not using a genuine vcds but a Aliexpress vcds copy?I make and sell tail light change harness for A3 8V. I have never heard 31347 not working in 09 on any A3 8V, including Prefacelift and Facelift.
Your issue is something else Not wrong code.
There is a good chance of that. I send coding with harness and never heard the security access 31347 not working for anyone using vcds or obd11 proCould it be not using a genuine vcds but a Aliexpress vcds copy?
Hey mate, can you please help me out with the coding for pfl led to fl led, I have a proper vcds unit nowAnyone doing A3 8V Taillight conversion can send me PM if needing any info/help or harness/coding
There are multiple variations between 3 door 5 door and saloon/cabriolet, between PreFaceLift and Facelift, both Halogen and LED, connectors are different, and coding is different.
CHANNEL | BEFORE | AFTER |
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 | 100 | 127 |
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 | 100 | 127 |
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 | Blinken rechts Dunkelphase | not active |
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 | Blinken rechts Hellphase | not active |
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 | 38 - LED Blinkleuchten | not active |
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 | 18 | 0 |
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 | 42 | 0 |
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 | 100 | 0 |
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 | Blinken links Dunkelphase | not active |
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 | Blinken links Hellphase | not active |
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 | 38 - LED Blinkleuchten | not active |
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 | 8 | 0 |
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 | 41 | 0 |
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 | 100 | 0 |
