Started the S3 and it's idling very rough and nothing happens when I press the accelerator.
O Omar17 Registered User Joined Sep 30, 2017 Messages 22 Reaction score 1 Points 3 Age 25 Oct 3, 2017 #1 Started the S3 and it's idling very rough and nothing happens when I press the accelerator.
<tuffty/> Badger 5 Edition...Its all about the flow... Staff member Moderator Joined Sep 14, 2008 Messages 24,836 Reaction score 6,077 Points 113 Location Wibbleton Website www.tuffty.co.uk Oct 3, 2017 #2 MAF most likely... unplug the MAF for now, that should get you going... restarting the engine also works but only until it faults again... Check for fault codes... sounds like you will have a torque limit 2 exceeded code <tuffty/>
O Omar17 Registered User Joined Sep 30, 2017 Messages 22 Reaction score 1 Points 3 Age 25 Oct 3, 2017 #3 <tuffty/> said: MAF most likely... unplug the MAF for now, that should get you going... restarting the engine also works but only until it faults again... Check for fault codes... sounds like you will have a torque limit 2 exceeded code <tuffty/> Click to expand... Thank you, disconnected it and it's better than before
<tuffty/> Badger 5 Edition...Its all about the flow... Staff member Moderator Joined Sep 14, 2008 Messages 24,836 Reaction score 6,077 Points 113 Location Wibbleton Website www.tuffty.co.uk Oct 3, 2017 #4 Faulty MAF most likely but validate from a fault scan and post up the results <tuffty/>
O Omar17 Registered User Joined Sep 30, 2017 Messages 22 Reaction score 1 Points 3 Age 25 Oct 3, 2017 #5 <tuffty/> said: Faulty MAF most likely but validate from a fault scan and post up the results <tuffty/> Click to expand... The S3 was sat for awhile, it is idling fine now, thanks for your help
<tuffty/> Badger 5 Edition...Its all about the flow... Staff member Moderator Joined Sep 14, 2008 Messages 24,836 Reaction score 6,077 Points 113 Location Wibbleton Website www.tuffty.co.uk Oct 3, 2017 #6 Omar17 said: The S3 was sat for awhile, it is idling fine now, thanks for your help Click to expand... Doesn't mean its fixed dude <tuffty/>
Erikn89nl Registered User Joined Oct 12, 2014 Messages 954 Reaction score 393 Points 63 Location Netherlands Oct 9, 2017 #7 <tuffty/> said: Doesn't mean its fixed dude <tuffty/> Click to expand... Sure it does, and he can now claim he's gone MAFless For those of you of who do not speak sarcasm... this was it.
