Audi S3 idle problem
Omar17
Started the S3 and it's idling very rough and nothing happens when I press the accelerator.
MAF most likely... unplug the MAF for now, that should get you going... restarting the engine also works but only until it faults again...
Check for fault codes... sounds like you will have a torque limit 2 exceeded code
<tuffty/>
<tuffty/>
Thank you, disconnected it and it's better than before
Faulty MAF most likely but validate from a fault scan and post up the results
<tuffty/>
710
11
835
