BKD engine mount
sandraj0719
Member
Hi everyone and sorry in advance if this has been asked before.
I am swapping engines over as cam belt snapped on a bkd engine but when I was buying the cambelt kit they told me to change the mount to new one as makes life easier.
My question is do they mean the engine bracket as heard this is difrent as some you don’t need to remove and if so how do you update it as part numbers all look the same?
Thank you for any help or clarification.
Found out if I get the new engine bracket and bolt n10683301 for the cam belt roller as it is longer it saves supporting the engine on cam belt Change.
So how do you go about getting the belt over it if the engine mount is still mounted ( cut and glue the belt together :tearsofjoy:)
