Decoding RNS-E Mk 1 needed urgently!
georgyporgye
Chapel-en-le-Frith
Hi there ,
Can you recommend anybody good at coding/decoding Audi Navigation Plus RNS-E Mk 1 on Audi A3 1.6 tdi?
Due to incompetent messing with it my phone wont connect any more!
I'm near Stokport , Manchester area!Post code SK23 Derbyshire
Please advise!
George
Hi ,is there anybody good at coding/decoding Audi Navigation Plus RNS-E Mk 1 on Audi A3 1.6 tdi?
Please advise!
George
Reset the unit to factory settings
Hold down RADIO and SETUP if i remember correctly ?
It is retrofit !
It needed coding as the phone option had to be activated.
The phone contacts were only visible on the dash display
Somebody that had a cable had a go and now the phone wont connect via Bluetooth at all
If it is an Apple phone try this , switch off bt put your phone into airplane mode then turn phone off then on check that airplane mode is off then put Bt back on see if your contacts appear
I think he needs someone with vcds to code it in for him as he says it’s a retrofit.
Does your car have a Bluetooth module installed as you’ll need that aswell for the phone to work?
445
NHN
516
