Fitting puddle lights back and front. Am I correct that it's pins 18. 19 which is earth rears 1.2 how do I separate plug the pins go into
Mines doesn't have zip tie on it also my wires only has on3 connector I can get round this by earthing it but to whereSounds correct. When you unplug the purple connector, there all be a zip-tie or loom tape at the top. Remove this, lift the little lug and the inner white section will slide out. It's possible that the pins are currently empty so you new wires should just push in.
Yeah I have one that I got for something else can use that will earth rear separateUndo the Loom Tape
re the wires, do you have a repair wire you can use? I guess wiring to earth would work.
Thanks mateYeah I have one that I got for something else can use that will earth rear separate
It's all done now mate getting coded satHave a look here mate ( http://www.audi-sport.net/xf/threads/my-diy-guide-for-retro-fitting-puddle-lights.58244/ )
Hi mate all done didn't have another repair wire so I just earthed it to the door undid a screw scratched behind it and happy days.Yeah I have one that I got for something else can use that will earth rear separate
If you want a repair wire let me know and i will give you a shout once homeHi mate all done didn't have another repair wire so I just earthed it to the door undid a screw scratched behind it and happy days.
Thanks mate it's all done. Offer of repair wire great if you've one just knocking about.If you want a repair wire let me know and i will give you a shout once home
