Puddle lights
leonwilliams
West Yorkshire
Fitting puddle lights back and front. Am I correct that it's pins 18. 19 which is earth rears 1.2 how do I separate plug the pins go into
Sent from my SM-G935F using Tapatalk
Sounds correct. When you unplug the purple connector, there all be a zip-tie or loom tape at the top. Remove this, lift the little lug and the inner white section will slide out. It's possible that the pins are currently empty so you new wires should just push in.
Mines doesn't have zip tie on it also my wires only has on3 connector I can get round this by earthing it but to where
Undo the Loom Tape
173b6cde5c4b1899529898570394cea7
re the wires, do you have a repair wire you can use? I guess wiring to earth would work.
Yeah I have one that I got for something else can use that will earth rear separate
Hi mate all done didn't have another repair wire so I just earthed it to the door undid a screw scratched behind it and happy days.
If you want a repair wire let me know and i will give you a shout once home
639
33
NHN
926
