ABS not kicking in
Solberg
Age
31
Norway
Got 4 pot brembos on the front of my S3, when breaking hard the front wheels lock up, no vibrating in steering wheel or any sign of ABS kicking in. Scanned with VCDS and there is no faults in the ABS system there it says.
Any ideas? ....MOT time...
Oups I got this code stored:
16885 - Vehicle Speed Sensor: Implausible Signal
P0501 - 35-10 - - - Intermittent
I thught it was the speed sensor on the gearbox, could this be the ABS sensor on the hub not working? Kinda veird I dont think Ive ever felt the ABS engange on my car, and now with winter tyres the brakes locks extremly fast, if its just a little gravel or sand on the road it locks on all kinds of wheel just like it wants to. No ABS ligh in dash....
Also:
Address 03: ABS Brakes Labels: None
Controller: 8N0 907 379 A
Component: ABS/EDS 20 IE CAN V001
Coding: 13504
Shop #: WSC 06435
VCID: 3A07B1EB3547
No fault code found.
Vehicle speed sensor (G22) is on the back of the gearbox. Check the plug and sensor terminals for corrosion as it’s common for the seal to split causing water ingress
