Made an RS4 Grille for my S Line.
boffin486
Aberdeen
Spent the last couple of days making an RS4(ish) front grille for my A4 B7 Quattro Avant.
Original unmodded car & mucked about on the PC to create a notion of what it will look like.
01 Grille mod Mockup
After obtaining a 2nd Grille from FleaBay, The Game Is On!
03 Two Grilles
First Remove the chrome surround trim and the Number Plate Holder.
05 Remove Num Plate Holder  Chrome Trim
Next I cut out the lower grille Bars.
07 Cut out lower grille
I got a sheet of suitable plastic mesh (Fleabay again) ready for the transformation.
06 Grille  new Mesh Sheet
Cutting out the Grille Bars leaves a lot of V shaped cutouts in the Surround which would weaken the Frame.
Solution – fill them with Hot Melt Glue. 1st, taped over holes with Cloth Tape.
08 Tape over holes in Frame
Now fill in the cutouts with Hot Melt Glue from the other side.
09 Hot Melt  Glue to fill Holes
Wait for the glue to set solid, remove the tape & with some tidying up/sanding, the frame is much stronger.
Next make a template & cut out a section of mesh to fit.
10 Make a template for New Mesh
Now glue the mesh into the Frame. Time consuming but seems to work well.
11 Glue Mesh into Surround
Now the first Slot is filled – Looks quite good.
12 Lower slot now Mesh Filled
Now repeat the process with the upper grille – Cut out the Bars
14 Upper grille Removed
Create a template, cut out the mesh, glue it into the prepared frame.
16 Glue Mesh into Surround 2
Next – need the Badge Mount out of the old grille - you CANNOT get these anywhere unless you buy a new grille, believe me, I have tried!
17 Old Grille Badge Mount
Easiest tool for this is a Dremel or similar device with a cutting disk.
19 Grille chopped up
Audi Badge Mount Front  Rear
Now remove the centres so the mesh shows behind badge instead
23 Remove the Centres 2
Now, after some fettling/tidying up, I Glued the Mount onto the Grille & then painted the whole lot with Satin Black Bumper Spray Paint.
26 Badge mount Glued to Grille
Grille almost finished, just needs the Badges/Trim replaced. I like the chrome trim so kept it but it could be painted black if required.
Bumper with old grille removed, ready for new grille.
27 Bumper ready for New Grille
Grille with new badges & trim installed into Bumper.
28 Grille with New Bages  Trim Installed
Now decided to match the Fog Lamp Grilles – Similar procedure, smaller scale.
30 Fog Lamp Surounds
32 Mesh cut to Fit
Cut out Mesh glued into place
34 Mesh glued in Place 2
Finished Result, Just need to do it twice!
35 Finished Fog Lamp Grille
Fit them into the Bumper & it’s ready for fitting.
Bumper re-installed on Car (best done with some help as getting everything lined up to slot in is a bit of a pain).
36 Bumper Ready to refit
37 Bumper Refitted
Final Result – Reasonably good. If I did it again I might use a different procedure to make it easier. Added bonus - leaves and other stuff don't gather behind the fog lights...... :rugby:
DSC 0755
I have turned this into a Word Document (has a few more pics) as well so PM me if you want a copy.
Reactions: RichMk3, KrisKrk, THQuattro and 4 others
Looks very smart chap, not sure on the red badge color to be honest but personal choice , good work all the same.
Reactions: KrisKrk
I forgot to add - changed the rear badge to match - I thought the red logos work on the S Line theme with its red badges.
39 New Rear Audi Rings
Reactions: DieselJake
Some excellent work there...
...ruined by those chavvy red badges.
Reactions: VAG-Slag and KrisKrk
Fantastic work! :icon thumright:
I like how you've made it your own with the colour, reminds me of a few things I've done that people haven't agreed with just because it's different to the norm (aka not boring) but haters gonna hate like you say it's your car, keep up the good work.
Great work.
When I had A4, I wanted to do same grille mod. Passed on that to invest time elsewhere but made same mesh on my A6 fog grilles.
Keep it up with excellent labour and write ups
Great mod mate, looks really good.
I keep looking at mine thinking I'm gonna do this, I've looked around for plastic mesh that has a slightly bigger honeycombe, but it's hard to find..
Hi Rich, When I chose the mesh, I specifically chose a smaller honeycomb as I prefer the look but there was another one readily available with a larger honeycomb. I'll look it up again after work on fleabay and post the item number so you can have a looksee.
Reactions: RichMk3
Cheers mate, that would be great :icon thumright:
And I'm still jealous of your ample ramp!! :yes:
Hello again Rich - have a look at:
eBay item number: 222650207775 (this is the one I used)
eBay item number: 141794307446 (bigger mesh size)
If you look at the other choices available too, I'm sure you'll find what you want.
:hi:
Reactions: RichMk3
Hey mate excellent work that, well done, I might try that myself as it's the only option I think, I only got the car yesterday (2007 a4 b7 cabriolet s line 2.0tfsi) and I'm already thinking of modernising it, but I'm quickly learning that there is not much plug and play stuff for them and if I'm right here (still learning) the rs4 grille is a fortune and the ebay ones don't fit, might be the only way
Yep, I've been watching genuine RS4 grilles on ebay & have actually seen one advertised for...................................... £1400.00 !!!
YES Fourteen. Hundred. Pounds...... :blink: ................
Totally stupid price for a bit of plastic worth £20.00, that's my opinion anyway mate, I think yours looks just as good, I might just spray my original grille gloss black which will get rid of the chrome and improve the look and be done with it, although I've got bigger fish to fry at the moment as the car in the garage this morning for a gap in the window, so I'm keeping my fingers crossed this is gonna work out OK, thanks for the reply mate, cheers marty.
If I just spray the original grille I guess it would look something like the pic, if I attempt the mod in the future, how well will the glue hold the mesh in place? Be no good if first downpour we get and it starts coming apart if you know what I mean mate, yours looks made to last my effort might not be lol. DSC 1171 copy 1024x681
There are rs4 grilles around for sensible prices, just not always when one needs them ,they are probably the most sought after grille around so getting more of supply and demand item.
Hia Rob, nice to meet u mate , yeh I know what you mean I just cudnt justify forking out £500+ for one at the mo that's all, I think boffins DIY looks great and I also think just spraying or powder coating the original s line grille matt black wud look cool too, what do you think mate? Thanks Rob, cheers marty.
If you have an s-line bumper on your cab then choices are very limited, but if you have a non s-line bumper then there are lot more aftermarket options.
Not all cabs with the s-line pack actually have the b7 s-line bumper, what's yours got fitted.
Yep , that's an s-line, welcome to the world of. Very limited choice.....lol
Lol yeh I started to realise that from day one ha, but it's not all bad I think I've found some aftermarket headlights that will modernise the front end if theres no fault codes of course lol I'll put a pic up in bit, thanks Rob, cheers marty.
