ABS Pump coding
Tomca
Hello, recently had to replace my abs pump which now needs coding to my car. Can the code be determined from the codes in the service booklet or is a scan required?
Received 694308864301841
Did you not take the coding from the old pump before you fitted the new one?
No, but i do still have the old pump. Took it off, bought new one and fitted it - can coding not be determined another way?
Ross Tech website has a guide on coding the MK60 abs pump. Take a look at that.
Ah okay, just taken a look.. So its just as simple as adding up the values of the relevant parts on the car?
Yes but you will also need to carry out basic settings i would imagine for steering angle etc...
Reactions: Tomca
Simples if you have done autoscan b4 you only need to go into your tosstech folder find it , open it and note coding then just apply that to your new pump and then do what else you need to do .
Reactions: Tomca
Always mind when using a vcd's cable do an AUTOSCAN first and save it before clearing any codes or fitting new equipment that needs coded
Cheers, definitely will if needed in the future.
Car is going to a garage on Wednesday to get coded
798
861
NHN
