Brwnstainz
Hi all,
As I’ve had help on this website a lot I thought I would write this for any others in need of help.
I was getting no air coming out from the window vents but all the other vents were working ok so I decided to have a look.
Turns out there are 4 motors controlling the air flow and hi/low temperatures (this is if it has dual climate, for single climate I’m not so sure).
These are found on the heater unit which is behind dash and directly behind the radio / stereo. The motors are on the side of the heater unit which 2 are on the passenger side which you can get to by taking the glove box off, the top one is for re-directing the air flow, the bottom one is for hi/low passenger side.
The other 2 are on the driver side next to the clutch pedal, the top one is for the window vents at the top of the dash and the bottom I presume is for hi/low temp driver side.
Took me a while to figure this out so hopefully this will help others trying to find the same.
