Have a look through this link ( https://audi.7zap.com/en/ )
If you can wait.Wow thank you so much I have just bought it . I owe you one.
Thanks again .
Have replaced the unit with a new aftermarket (cheap) one today and the fuse that had blown, but the eml will not go out. Tried the ecu reset procedure as outlined in other posts and still eml is alight.
Don’t want to sound flippant but I always believe in the adage of “ buy cheap, buy twice”.
When my ASV went I bolted in a Pierburg replacement (same make as the Genuine item removed) , replaced the fan fuse and the EML light went out.
Hi Nessy,
Totally get what you’re saying and that’s what I’m wondering if the part being cheap may have an electrical issue or just be ****. Just thought as it was such a basic part would give it a go. Have been looking at alternatives and I can see ‘good’ brands are 200-300 with voucher codes.
Just wondering if it could be anything else like the fuses that could be causing issues before I buy a more expensive unit and try again.
Have found your posts to be the most helpful
Ok, lesson learnt I bought a Pierburg part from eurocarparts and it’s on offer again this weekend! So that’s a bonus!
Car is now working fine and the eml is finally out. Now to return faulty cheapo part and wait for the next problem...
Cheers Nessy,Glad to hear you’ve got it sorted!
It’s a very annoying part to have to replace though as the car drove perfectly well with the duff ASV (I’m sure mine failed in the open position ) ; only the EML being on and the fault code gave the game away....
A lot of money just to extinguish a dash light......
