Adaptive lighting defective light
vaf888
Hi Guys
Anyone had this fault and what could be the issue with the adaptive lights?
Is it easy the check the bulbs, leveling sensor, etc. Any advice on how to locate and access the above components would be great.
Can the warning light or adaptive lights be disabled via the hidden menu as the car is going for mot?
All
Sent from my Nexus 5X using Tapatalk
There is a fuse you can remove.
Removes warning on dash too you level headlights manually.
Not sure which fuse it is I done it on my old 59 plate a4 think there's a YouTube vid or article online.
Possibly axle sensor broken, happens on arm snaps, speculative without seeing the car.
Guys. Motors within the headlights are working. So I think it could be down to the leveling sensor within the passenger side. Anyone have a part number?
Check the sensor 1st before condemning, usually these get broken with suspension work unbeknownst to owner.
This happened a two years ago and it was down to the sensor arm coming away. Garage simply reconnected it. Check it today and all connected. Sprayed with WD, but still error. So think I will just change it out as this was the problem the last time. Cheap enough on ebay
