Hi
I'm in the process of getting my engine rebuild due to a piston ring failure. (CDL)
I've decided to forge the bottom end
List is as follows
Forged Rods & Pistons
New big end bearings
Cylinder head overhaul
New gaskets
Upgraded Head gasket from aks
Apr main head stud kit
New oil pick up pipe
All new filters genuine
Cambelt waterpump
New pcv (getting rid of the pcv delete)
R8 valve springs from aks
New coil packs
New plugs
Injectors will be tested and replaced if necessary.
Also getting a dsg and Haldex service.
Now my main question
Is there anything else I should do whilst it's all apart
Currently running a tte420 possibly will change go bigger turbo in the future.
List is as follows
New gaskets
Cambelt waterpump
New coil packs
New plugs
