Custom turbo inlet pipe for K04
cstmn
Bulgaria
1FB0CCD5 8849 4E05 ADDC 419FF1BBC898
22684FEA 8A0C 40FA 881B 13C7047F7218
Hello. Someone with this one custom TIP for k04 turbo from hg-motorsport to express an opinion???
Agree’d only real one out there worth considering is Badger5’s ones. Oversized ;) check them out.
Reactions: hydro s3 and Tj 0785
I know it, but I have a problem. My car is LHD and does not fit... :(
I see your problem, I’m sure I read somewhere you can get them to fit with a bit of trimming..... it’s the pipes from the brake servo that’s the issues isn’t it from memory?
I will look again.
Here is a homemade 76mm inlet for LHD. 2 silicone elbows - 51 -76mm; 76 -76mm and the metal pipe(76mm) needed to be bend a bit in oval shape due to master cylinder pipes.
And I will do this. Thank you!
You can make the one from Bill Badger fit as well just have to trim it a bit. Had some pictures but no idea where they are now. But it does fit.
LHD tip is not hard to do. 3" TIP is bit hard to fit there but if you put rubber top of silicone hose, it wont rub itself out.
You need couple 90 degree silicone hoses and cuple 90 degree SS tight corner bends.
Heres couple pics. first is version 2 and last is version 4
Remember these are for my cone filter, not OEM
