Facelift Led daytime rear lights
Tzsteve
Age
49
Westmeath
Hi all.
The led rear lamps on my a3 sline stay on regardless as to what position the switch is in.
Is it possible to have them coded to switch off?
In my old a4 b8 the front drl's came on in the off position but the rears stayed off unless the lights were on.
There is no current law in this country regarding rear DRL.
This is my first car to have rear DRL and I initially thought there was something wrong.....but now I think it's a good idea and I am happy for my rear lights to be always on.
It means that my car will always be visible whenever the engine is running.
Rear DRL are only available with full LED lights, which have a very long life so you should not have to worry about premature failure.
Reactions: KenL
I'm not concerned about premature failure as they should last the life of the car....However I do know of 2 people who had issues and had to have the whole lamp unit replaced....Under warranty thankfully as they are eye wateringly expensive.
Id just prefer to have the option to switch them off if possible.
Yes I believe it should be possible to turn them off using the right equipment. :)
Give it a little while to think about it though, because they are actually a good thing.
Reactions: Tzsteve
Apologies for the thread drift, but what I don’t understand is why Audi have activated the rear DRLs on some models as standard from the factory, i.e. later S3, but not on others, such as my 2018 Q5........it doesn’t make sense??
I have thought about it.. Would just like the option
Carista enables this to be turned off and on. I turn them on in the winter and off in the summer.
Reactions: Tzsteve
G
79
17K
D
483
Deleted member 117185
D
4K
