electronicstuff
Hi, I have developed a fault with my A3, The engine code is BMN
The car is cutting out at around 2400 rpm, when this happens the revs drop and you can hear a relay clicking from under the dash. This results in kangarooing effect most of the time, but sometimes just dies completely, will normally restart fine, This also happens when parked up and reving the engine.
There are no dash lights and when scanned with vcds there are no codes.
The fact it seems to happen at 2400 rpm and the relay clicking, it seems as if something is causing the signal to the relay to be turned off thus shutting the car down, yet once below that rpm range it will come back on. Dash remains as normal, just like the car is still running.
At first I thought it may be a fuel issue and replaced the in tank lift pump and fuel filter, its not like an over boost issue, kinda feels like the fuel injectors are being shut off, but like I say no error codes in vcds or dash lights, drives fine so long as you keep the rpm below 2400 which is hard to do (can't accelerate quickly and no fast roads)
I hope someone on here has an idea of whats going on as I'm at a loss now, tia
