Hi I’ve bought an Audi A3 8v facelift with light front passenger side damage, damage was to headlight and behind, no chassis leg damage but has damaged the upper inner wing also the fuse box was hit and damaged and Ecu knocked battery tray ect ect
I have replaced the fuse box under bonnet, battery tray and have a replacement inner wing to weld in. Originally I had a lot of faults on the dash, power steering wasn’t working airbag lights Esc fault ect ect. Since fitting the new fuse box the power steering working again and it solved most of the faults. I’m scratching my head about the remaining faults and was hoping you guys would be able to point me in the right direction.
Firstly when I bought the car the person I got it from had bridged constant power in fuse box to the fuel pump wire! Without this bridge the car won’t start and when ignition is off the fuel pumps on and the fan kicks in but when you turn the key to ignition on the fan turns off? With wire removed there’s no fuel pump prime with ignition? I’m using an obdeleven pro and it’s giving me fault code P068900 PCM power relay sensor circuit de energised to slow? Also have a fault for no basic settings for dash. Is there some sort of fuel cut safety system in this car so when it senses impact it cuts of fuel? Or is it a power replay fault? I have the diagram for the fuse box’s but it does not tell me what relays are what just the fuses. It’s a 2017 1.6tdi Audi A3 8v 3door if anyone can help me out I would really appreciate it.
