john waring
Can anybody help me and tell me my problem the car is a 2004 BKD DSG that does not start so need help. Please see the vagcom read out.
Address 01: DTCs cleared
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 77 7D
VIN: WAUZZZ8P Mileage: 298040km-185193miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 016 DT HW: 028 101 189 2
Component: R4 2,0L EDC 0000AG 7000
Revision: 12345678 Serial number: AUX7Z0DDFNG0DV
Coding: 0000078
Shop #: WSC 80093 222 69422
VCID: 78FF9B640BB8DE8420-802C
3 Faults Found:
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Freeze Frame:
RPM: 0 /min
Torque: 80.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.26 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 92.0 Nm
18617 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High
Freeze Frame:
RPM: 0 /min
Torque: 80.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.26 V
Bin. Bits: 00000100
Temperature: 22.5°C
Temperature: 27.0°C
17075 - Fan 1 Control Circuit
P0691 - 000 - Short to GND
Freeze Frame:
RPM: 0 /min
Torque: 80.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.26 V
Bin. Bits: 00000100
Temperature: 22.5°C
Duty Cycle: 9.6 %
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 041 A HW: 02E 927 770 AD
Component: GSG DSG 041 0822
Revision: 04004010 Serial number: 00000411270393
Coding: 0000020
Shop #: WSC 06314 000 00000
VCID: 102FC3C40308E6C488-8044
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023174
Shop #: WSC 06435 000 00000
VCID: 3A7B416C75340C9416-806E
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 K HW: 8P0 820 043 K
Component: KlimavollautomatH14 0180
Revision: 017393 Serial number: 8P0820043K
VCID: 34676F545750FAE4CC-8060
6 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 183
Mileage: 298040 km
Time Indication: 0
Freeze Frame:
Voltage: 8.30 V
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Date: 2017.09.19
Time: 00:11:25
Freeze Frame:
Temperature: 45.5°C
00483 - Control Module for Auxiliary Air Heater
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 143
Mileage: 291050 km
Time Indication: 0
Date: 2016.09.02
Time: 00:12:24
Freeze Frame:
Temperature: 29.0°C
01301 - Control Module for Voice Recognition (J507)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Date: 2017.09.26
Time: 00:00:27
Freeze Frame:
ON
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Date: 2017.10.17
Time: 00:00:12
Freeze Frame:
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H34 0301
Revision: 00H34000 Serial number: 00000001342646
Coding: 01884F06A214100000000000000000000000FE0F5C
Shop #: WSC 06314 000 08192
VCID: 3D714A70641A3BAC33-8068
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
2 Faults Found:
01117 - Generator Terminal DF Load Signal
01049 - Supply Voltage Term 50
006 - Short to Plus
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0011603
VCID: 43853C8802FE4D5C45-8016
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 B HW: 8P0 953 549 B
Component: Lenksäulenmodul H21 0050
Coding: 0011112
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H04 0040
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 A HW: 8P0 920 981 A
Component: KOMBIINSTR. VDO H73 0300
Revision: D04 Serial number: 224DDD04004088
Coding: 0000446
Shop #: WSC 00557 067 57207
VCID: 3663555C412CE8F4F2-8062
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 2500104C070508
Coding: 3F0F0BC0070101
VCID: 285F8B249B988E0470-807C
1 Fault Found:
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Date: 2017.10.17
Time: 00:12:18
Address 25: Immobilizer
Cannot be reached
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0030
Coding: 0000048
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.8 1502
Shop #: WSC 00000 000 00000
VCID: 31696640A842CFCCA7-8064
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 E
Coding: 0000048
VCID: 3E734D7C691C20B42A-806A
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 195 HW: 8P0 035 195
Component: symphony II EU H57 0410
Revision: 22S Serial number: AUZ5Z4D6063131
Coding: 0021221
VCID: 6FEDA0387EF6993CF1-803A
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Date: 2017.10.17
Time: 00:12:16
Address 77: Telephone
Cannot be reached
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D517A30B47AAB2C83-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End---------------------(Elapsed Time: 02:17, udsna)-----------------------
Coding: 0000078
3 Faults Found:
Freeze Frame:
RPM: 0 /min
Torque: 80.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.26 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 92.0 Nm
Freeze Frame:
RPM: 0 /min
Torque: 80.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.26 V
Bin. Bits: 00000100
Temperature: 22.5°C
Temperature: 27.0°C
Freeze Frame:
RPM: 0 /min
Torque: 80.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.26 V
Bin. Bits: 00000100
Temperature: 22.5°C
Duty Cycle: 9.6 %
Coding: 0000020
Coding: 0023174
6 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 183
Mileage: 298040 km
Time Indication: 0
Freeze Frame:
Voltage: 8.30 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Date: 2017.09.19
Time: 00:11:25
Freeze Frame:
Temperature: 45.5°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 3
Reset counter: 143
Mileage: 291050 km
Time Indication: 0
Date: 2016.09.02
Time: 00:12:24
Freeze Frame:
Temperature: 29.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Date: 2017.09.26
Time: 00:00:27
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Date: 2017.10.17
Time: 00:00:12
Freeze Frame:
Coding: 00062736
Shop #: WSC 06314
2 Faults Found:
006 - Short to Plus
Coding: 0011603
Coding: 0011112
Coding: 0000446
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Date: 2017.10.17
Time: 00:12:18
Cannot be reached
Coding: 0000048
2 Faults Found:
1 Fault Found:
000 - -
Cannot be reached
Coding: 0000048
Coding: 0021221
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Date: 2017.10.17
Time: 00:12:16
Cannot be reached
1 Fault Found:
014 - Defective
