Help with my A3 8P DSG
john waring
Halesowen
Can anybody help me and tell me my problem the car is a 2004 BKD DSG that does not start so need help. Please see the vagcom read out.
Address 01: DTCs cleared
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 77 7D
VIN: WAUZZZ8P Mileage: 298040km-185193miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 016 DT HW: 028 101 189 2
Component: R4 2,0L EDC 0000AG 7000
Revision: 12345678 Serial number: AUX7Z0DDFNG0DV
Coding: 0000078
Shop #: WSC 80093 222 69422
VCID: 78FF9B640BB8DE8420-802C
3 Faults Found:
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Freeze Frame:
RPM: 0 /min
Torque: 80.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.26 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 92.0 Nm
18617 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High
Freeze Frame:
RPM: 0 /min
Torque: 80.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.26 V
Bin. Bits: 00000100
Temperature: 22.5°C
Temperature: 27.0°C
17075 - Fan 1 Control Circuit
P0691 - 000 - Short to GND
Freeze Frame:
RPM: 0 /min
Torque: 80.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.26 V
Bin. Bits: 00000100
Temperature: 22.5°C
Duty Cycle: 9.6 %
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 041 A HW: 02E 927 770 AD
Component: GSG DSG 041 0822
Revision: 04004010 Serial number: 00000411270393
Coding: 0000020
Shop #: WSC 06314 000 00000
VCID: 102FC3C40308E6C488-8044
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023174
Shop #: WSC 06435 000 00000
VCID: 3A7B416C75340C9416-806E
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 K HW: 8P0 820 043 K
Component: KlimavollautomatH14 0180
Revision: 017393 Serial number: 8P0820043K
VCID: 34676F545750FAE4CC-8060
6 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 183
Mileage: 298040 km
Time Indication: 0
Freeze Frame:
Voltage: 8.30 V
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Date: 2017.09.19
Time: 00:11:25
Freeze Frame:
Temperature: 45.5°C
00483 - Control Module for Auxiliary Air Heater
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 143
Mileage: 291050 km
Time Indication: 0
Date: 2016.09.02
Time: 00:12:24
Freeze Frame:
Temperature: 29.0°C
01301 - Control Module for Voice Recognition (J507)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Date: 2017.09.26
Time: 00:00:27
Freeze Frame:
ON
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Date: 2017.10.17
Time: 00:00:12
Freeze Frame:
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H34 0301
Revision: 00H34000 Serial number: 00000001342646
Coding: 01884F06A214100000000000000000000000FE0F5C
Shop #: WSC 06314 000 08192
VCID: 3D714A70641A3BAC33-8068
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
2 Faults Found:
01117 - Generator Terminal DF Load Signal
01049 - Supply Voltage Term 50
006 - Short to Plus
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0011603
VCID: 43853C8802FE4D5C45-8016
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 B HW: 8P0 953 549 B
Component: Lenksäulenmodul H21 0050
Coding: 0011112
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H04 0040
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 A HW: 8P0 920 981 A
Component: KOMBIINSTR. VDO H73 0300
Revision: D04 Serial number: 224DDD04004088
Coding: 0000446
Shop #: WSC 00557 067 57207
VCID: 3663555C412CE8F4F2-8062
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 2500104C070508
Coding: 3F0F0BC0070101
VCID: 285F8B249B988E0470-807C
1 Fault Found:
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Date: 2017.10.17
Time: 00:12:18
Address 25: Immobilizer
Cannot be reached
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0030
Coding: 0000048
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.8 1502
Shop #: WSC 00000 000 00000
VCID: 31696640A842CFCCA7-8064
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 E
Coding: 0000048
VCID: 3E734D7C691C20B42A-806A
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 195 HW: 8P0 035 195
Component: symphony II EU H57 0410
Revision: 22S Serial number: AUZ5Z4D6063131
Coding: 0021221
VCID: 6FEDA0387EF6993CF1-803A
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 143
Mileage: 298040 km
Time Indication: 0
Date: 2017.10.17
Time: 00:12:16
Address 77: Telephone
Cannot be reached
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D517A30B47AAB2C83-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End---------------------(Elapsed Time: 02:17, udsna)-----------------------
First thing to do would be to check the fuse for the motor flap, check the electrical socket connection to the flap, make sure pins are clean, clear fault code and see if it returns ?
Remove the boost pipe via the clip and see if the flap is stuck in the open position. If yes then this is not the cause of your starting problem.
If closed get a mate to hold the flap in the open position by wedging a large clean screwdriver in the flap to hold it open and try to start the car for a few seconds to confirm if this is your issue.
As said, now that you have a scan, delete the codes and then rescan and take things from there.
Ross Tech Wiki has lots of info if you google the code.
657
11
83
15K
925
