Ttrs brakes
S3sp
Athens
Good evening everyone I would like to ask a quick question I intend to put a ttrs bbk 4pot kit in my car and would like to ask if with my wheels as an ultraleggera 8x18 Et45 I will need spacer? thank you very much
I have been looking to do the same thing but be careful, people are asking more for TTRS calipers now than brand new Brembo's.......and the TTRS are just Brembo's anyway :) Vagbrem do a kit using the same callipers and call them Aston martin.
will these fit behind my stock BE rotors Sam ?
Hi @paddy - yeah they’re all the same kit. It’s surprising the range of vehicles these calipers are on from factory.
To fit behind rotors you’ll need spacers unfortunately. I think 12mm from memory but can’t confirm sorry.
Reactions: paddy
Cheers Sam, i have 12 rear and 10 front at the moment. I may just change the wheels as these are starting to corrode under the paint. shame because i wanted to keep it outwardly std. Bit of a sleeper :)
Reactions: samuelh_888
Yes they will fit, i just fitted mine behind Ultraleggra, running the 370mm discs leaves very very little clearance inside the barrel of the wheel, however from the back of spokes to the face of the caliber i have around 3mm so plenty, currently very pleased with the set up. I'm running m1144 pads, hel lines all round, rbf660 fluid and upgraded rear discs. Stops well however summer I'm changing to ap discs and RS29 pads
thanks so much for the info to ask another question with the spare whats up​
Probably easier to buy some red paint and some Brembo stickers. :)
Its difficult to know if 4 pots will really make a huge difference, the limiting factor is more likely the disc dia. by the time the 8v came out the std audi RS caliper was an 8 pot....
Pads are probably more important for road use where overheating and fade is not likely to be such a problem.
4 pots make a huge difference, grab is insane. its really made a massive difference to the overall car. i kinda wish i went ap racing kit now
μου βρήκε πολύ δύσκολο να τα βρω και να τα αγοράσω και δυστυχώς το κείμενο που βρήκα χρησιμοποίησε δίσκους φρένων Ξέρετε από πού μπορώ να σας φέρω καλή αξία άλλα νέα για να αντικαταστήσω τη δική μου τι θέλω να ρωτήσω είναι αν μένουμε με καουτσούκ τι για τον εφεδρικό τροχό
Yes but £2800 for the AP kit ? vs £1200 for the brembo 4 pot kit ?
Ναι φίλος μου, αλλά είναι ακριβό
I received your message indeed. It's a great kit but I don't have as much money to spend anymore thanks
για μένα
432
851
17
