I have a4 b6 1.9tdi 130. I have limited power no engine lights and no codes. I can here a sound under acceleration, sounds like when you blow the top of a bottle. Is this a pipe leak? If so which pipes should I check.
Check all the intercooler pipes all the way from turbo to intercooler.....I have a4 b6 1.9tdi 130. I have limited power no engine lights and no codes. I can here a sound under acceleration, sounds like when you blow the top of a bottle. Is this a pipe leak? If so which pipes should I check.
No it's there,The first pic looks like a hose clamp is missing?
Make sure that the turbo waste gate sistem is mowing freely.... To check it you need a vacuum pump tool https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/182355053748There are clips on both pictures should there be more. There is no misting around the connections so I would imagine there is no leak.
