Hi! I recently changed the clutch, but the issue didnt disappear 01270 010! I tested clutch with battery and it is engaging! There is power at the end of connector, so cold it be the ground is cut somewhere? If yes where from is it coming out and where connected cause it is only 1 pin power connector connected to compresor ?Not sure where is hvac module located ? Maybe anyone has wiring diagram?
