A/c magnetic clutch open or short to ground
cherrijs
Thurles
Hi! I recently changed the clutch, but the issue didnt disappear 01270 010! I tested clutch with battery and it is engaging! There is power at the end of connector, so cold it be the ground is cut somewhere? If yes where from is it coming out and where connected cause it is only 1 pin power connector connected to compresor ?Not sure where is hvac module located ? Maybe anyone has wiring diagram?
If you don't get any joy on here try a few of the Audi Facebook groups I've got some good technical advice off there in the past.
Sent from my moto e5 plus using Tapatalk
According to that screenshot, the DTC has occurred once with a date stamp of 2/8/2019. Are you telling us that you cleared it and it came back with that old date stamp?
No, thats the wright date, because of the winter coming i decide to leave that to next year! And i was pretty sure that was coil fault, so i changed one on september i think but that wasnt the issue!
Sorry, in that case you post doesn't make any sense to me. Hopefully other people will be able to help.
