hi,all cars had a front end collission after getting it fixed,getting this airbag fault below.
new bonnet hinges/igniters have been fitted,which are brand new and from audi.
any help on this problem would be appreciated 2014 A3 TDI.
Friday,05,June,2020,20:18:44:22644
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WAUZZZ8V1EA175244 License Plate: A3 8V (2014)
Mileage: 108113km-67178mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V1EA175244 Mileage: 108113km-67178miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 AL HW: 04L 907 309 B
Component: R4 1,6L EDC H22 6546
Revision: 84H22---
Coding: 02190012032501092000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM16TDI01104L906021AL 002011
ROD: EV_ECM16TDI01104L906021P.rod
VCID: 6FBBD14797188B33BA1-803A
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 607940000015F1
Coding: 12F18AA224270A710179060441C72548512450806082A4F2024100080608
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033.rod
VCID: 7BA3F517D360E793069-802E
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000280249
Coding: 03100104002000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 323D183344AAE6DB95F-8066
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 46090E17000000000001
1 Fault Found:
262658 - High Pressure Sensor
B10AE 31 [009] - No Signal
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 195
Mileage: 108113 km
Date: 2020.06.05
Time: 20:09:24
Outside air temperature: 13.5 °C
Engine speed: 0.00 /min
Compressor current: actual value: 0.000 A
Temperature after evaporator: 31.0 °C
System run time-Engine running time: 0 s
System run time-Terminal 15 on: 135 s
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011408601121
Coding: 07040A42C24122FD03844004B31C07A80000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_012.rod
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 140321 041 0580
Serial number: 140324180223
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22437376
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
Component: E1 - LDS MQB H05 0032
Serial number: 11 01 2014 00001268
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1402118TT
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000029276776
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831409101679
Coding: 0000040001
ASAM Dataset: EV_EPHVA14AU3700000 002018
ROD: EV_EPHVA14AU3700000_002_VW37.rod
VCID: 38292A1BA2D60C8BABB-806C
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R05ZAR2
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 4BC365D7C3409713F69-801E
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 002 003 14
Component: SideSensor_Df 001 0887
Serial number: 35767000000647304F0O
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 002 003 14
Component: SideSensor_Pf 001 0887
Serial number: 35867000000747304F0Q
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 401 903 14
Component: SideSensor_Dr 001 6149
Serial number: 3516502A914D3E72E0DQ
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 401 903 14
Component: SideSensor_Pr 001 6149
Serial number: 3526502BF142B1B2E27I
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 400 602 14
Component: FrontSensor_D 001 6149
Serial number: 3556502B712AB1B3D32F
Coding: 2D2D2D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 401 003 14
Component: PedP_Sensor_D 001 6149
Serial number: 2286502BB14D3E75932M
Coding: 2D2D2D
Pedestrian Protection Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 003 14
Component: PedP_Sensor_P 001 6149
Serial number: 2296502BB14D3E75412G
Coding: 2D2D2D
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 401 003 14
Component: PedP_Sensor_C 001 6149
Serial number: 23065029F14D3E72B15H
Coding: 2D2D2D
1 Fault Found:
9451537 - Igniter 1 for pedestrian protection
B1038 11 [137] - Short to Ground
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 108113 km
Date: 2020.06.05
Time: 20:13:03
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 BP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 27031408491203
Coding: A408
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 094F9FDF89BCC503045-805C
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 970 N HW: 8V0 920 970 N
Component: KOMBI H03 2220
Coding: 27A40A002A8046000100A800100000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 47CB59E7DF287373D21-8012
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001756239
Coding: 030100040B0876005B000248080B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
VCID: 3FDB410787F83BB36A1-806A
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 15 03 2014 A0177455
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 9791302903
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 22031401100362
Coding: 00108E204001040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 40D942FBFA06444B13B-8014
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DF47FFF10C4D431C5-8014
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 23031401100322
Coding: 001086204001040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 018E000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75B7E32FF544B1E370D-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 874 B HW: 8V0 035 874 B
Component: MU-S-ND-ER 040 0420
Serial number: A7F02703142705
Coding: 01730301FF00000021111101000A00002F0001460100010006
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 3B23351793E02793469-806E
Display unit 1 for multimedia system:
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0013
Serial number: AUZ8Z9EY302ATW
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000007031400030362
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 B HW: 5Q0 959 595 B
Component: TSG HFS 020 0025
Serial number: 20031402090233
Coding: 000086204001040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 42DD48F3F40A565B05F-8016
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0025
Serial number: 20031406070232
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End----------(Elapsed Time: 01:17, VBatt start/end: 12.1V/12.1V)-----------
www.Ross-Tech.com
Revision: 84H22---
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 195
Mileage: 108113 km
Date: 2020.06.05
Time: 20:09:24
Coding: 0A47F7
Coding: 00006C
Light switch:
Alarm horn:
Coding: 0000040001
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 108113 km
Date: 2020.06.05
Time: 20:13:03
Coding: A408
Alternator:
Coding: 8103
