Replica Wheels
I run LDPrestige alloys during winter.
Never had any issues.
bfff9e795882aeb5f83f669006ebcc7d.plist
Do you happen to know what was the exact name for these? I kinda like them but there are 100's on that website. There's one which is similar but not 100%. Can't find these or maybe I'm blind.
Thanks,
D
Thanks @T-1000
Now that I decided to go with these in the 18'' variant, I see these confusing numbers:
Length
8.0 inches
Dimensions
18″ inches
Entraxe
5X112
Bore
66.5
Lower Bore Rings
Yes
What are these numbers and are they ok for my S-line? It's confusing as I don't see any ET number which I know it's important. I'm asking as I want the wheels to be exactly like the OEM ones, not pushed out or any other boy-racer style.
Sorry if I'm annoying but I really don't know anything about wheels.
Cheers,
Dan
Thanks @T-1000
Length
8.0 inches
Dimensions
18″ inches
Entraxe
5X112
Bore
66.5
Lower Bore Rings
Yes
Cheers,
Dan
You have an S3 ?
Here are the same wheel in your fitment according to the selector.
https://www.ldprestige.co.uk/jantes/ldp-ldm091-80-18-5112-45-66-pol-mgm
PCD / Offset explained below.
https://www.fixter.co.uk/blog/alloy-wheel-sizes-explained/
Reactions: DanZ
You have an S3 ?
Thanks for this. I have an A3 S-line.
These numbers are confusing me.
So, from what I read, my original wheel has a with of 7.5J. The one from your link is slightly wider an 8.0J so not sure if it's ok for me. Also, does anyone know what's the hub diameter for the A3? I don't want to spend that much plus the £50 for delivery to realise the wheels are not good for me.
Cheers!
Cheers!
Hub dia 57.1 mm they send spigot rings which you put in the alloy to adapt from 66 to 57.
Reactions: DanZ
Hi all.
I've decided to get some wheels from an uk based website as can't wait for international delivery and also I save on delivery.
I'm torn between Riva BVA and Romac Venom. What do you think, are these manufacturers ok or Chinese poo (it doesn't say where they are made).
Also, my OEM wheels are 18 7.5J ET51 whereas these are both 18 8J ET45. Is this a noticeable difference? The website says they fit to my A3 but better to double check.
Thanks.
Hi all.
Thanks.
I was going to get some Venoms but went for Bola CSR! Must admit I relied on the website to tell the truth so hopefully they fit when they come this week!
Having recently lifted an aftermarket replica wheel, and comparing it with an original, the weight difference is fairly substantial...
Reactions: DanZ
Hi all.
I think I know what I want regarding the allow make and model. The wheels I like are 18'' 8J ET45, the website selling them say that they fit but I have doubts. Willtheifit.com says that these wheels replacing my OEM of 18'' 7.5J ET51 will make the rim stick out 12 mm more than the originals. I had a look at the car and I just worry it might be too much as it seems that there isn't much clearance left.
Does anyone have the 18'' 8J ET45 setup on their 8V? Mine is an S-line.
Thanks!
Hi all.
Thanks!
OEM 19" S3 wheels are 19 x 8 with a ET49, so you'd have about 4mm difference I think with those you are looking at, which is nothing, as people run 10mm+ spacers a lot of the time, so it will be fine, and look better than the OEM 18" rims
Reactions: DanZ
Thanks!
Is the S3 suspension similar to the S-line however?
5mm lower, unless Magride is installed then its higher i believe
you need to check you have the s-line sports suspension and not the comfort suspension
Reactions: DanZ
Hi all.
One last question:
The wheels I've decided to buy are not having a symmetrical design which means they'll appear spinning in opposite directions nearside vs offside unless they are mirrored 2 and 2. I've called the seller and they aren't, all 4 are identical. In fact, I've called others too and for other similar designs and found that mostly all asymmetrical designed wheels come in one kind which means they'll have the above described effect. I mean, I'm not sure if that will bother me too much really and was wondering what's the general opinion on this.
Cheers,
Dan
Hi all.
One last question:
Cheers,
Dan
Wouldn’t let it bother you.
We had a Golf R FL with Spielberg’s on that had the same going on.
Reactions: Matt Adamson and pburv
Had my new Bola CSR fitted today! I am happy with the result!
Reactions: Dubjam
I have a set of non OEM alloys with winter tyres on and had to pay £11 more on my insurance, plus the £25 mid term adjustment and they put £100 on my excesses, would have been OK if OEM. Also have to let them know the date when I put them on and when I take them back off! Didn't dare ask about a remap!
Hi all.
Thanks!
these are 8J ET45 with 225/40/18 tyres
No rubbing and fit perfect
Reactions: DanZ
29
7K
594
