heres a scan
Thursday,05,November,2020,18:27:45:22644
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WAUZZZ8V9F10***** License Plate: AUDI S3
Mileage: 52892km-32865mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 26 42 44 52 55 5F A9
VIN: WAUZZZ8V9F10***** Mileage: 52892km-32865miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
26-Auto Roof -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A1D00322426010B2000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ECM20TFS0208V0906259A 001004
ROD: EV_ECM20TFS0208V0906259A.rod
VCID: 3E253C0380F232BB60F-806A
No fault code found.
Readiness: 1010 0001
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H52 4517
Revision: 03252204 Serial number: TFK01405222244
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1F1BE18727385BB34B9-804A
1 Fault Found:
10763 - Starter Enable from Selector Lever Sensor System
P1734 00 [002] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 61484000000769
Coding: 33F193A254232A6C017F070741C769CCC92A5480E08296F6024100F88608
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033.rod
VCID: 45D753EFE5246163215-8010
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 E HW: 8V0 820 043 E
Component: AC Automat H13 0052
Revision: 20000700 Serial number: 00000000318011
Coding: 05100004000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 34311E2BBEBEE8EB86B-8060
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 92F80137000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011414703366
Coding: 07041C47C24106FD03204004B11807A80100000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 005982FBBA86844B523-8054
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 140525 041 0585
Serial number: 140528142132
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22708575
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 G HW: 8V0 941 531 G
Component: E1 - LDS MQB H05 0032
Serial number: 27 03 2014 00000946
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY141050V64
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000029938502
Neck Heating Left:
Subsystem 6 - Part No SW: 8V7 963 579 HW: 8V7 963 579
Component: KRH375 links H14 0003
Serial number: P141562903702000159
Neck Heating Right:
Subsystem 7 - Part No SW: 8V7 963 579 HW: 8V7 963 579
Component: KRH375 rechts H14 0003
Serial number: P141562903702000158
1 Fault Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [008] - Electrical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 3
Reset counter: 167
Mileage: 52892 km
Date: 2020.11.05
Time: 17:29:09
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 E HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0051
Revision: -------- Serial number: 39231415700035
Coding: 0000050011
ASAM Dataset: EV_EPHVA14AU3700000 002022
ROD: EV_EPHVA14AU3700000_002_VW37.rod
VCID: 3B23351793E02793471-806E
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 C HW: 8V0 907 376 C
Component: DAEMPFUNGS-SG H08 0066
Serial number: 290514002
ASAM Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide.rod
VCID: 41DF47FFF10C4D431DD-8014
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 A HW: 5Q0 959 655 A
Component: AirbagVW20 009 0865
Serial number: 003ESR0098VY
Coding: 98C0C0000000A0005C5000CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002136
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 000 206 14
Component: SideSensor_Df 001 0887
Serial number: 3570000000098AA4CF0/
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 000 206 14
Component: SideSensor_Pf 001 0887
Serial number: 358000000008CAA4CF01
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 012 705 14
Component: SideSensor_Dr 004 0108
Serial number: 351001A01BF11ED23DBJ
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 4 - Part No SW: ----------- HW: 480 400 804 14
Component: FrontSensor_D 001 6149
Serial number: 35500029B1524DC3111Z
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 CB HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 06061404220247
Coding: A018
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 7CA1F60BD66EE0AB0EB-8028
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 971 J HW: 8V0 920 971 J
Component: KOMBI H02 4291
Coding: 27AD100A3B8026000101E8001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009040
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 44D14EEBEE1E586B36B-8010
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 28051410800736
Coding: 030100042F085A005B0002689C0B00000001010000000000000000000000
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_011.rod
VCID: 42DD48F3F40A565B047-8016
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 26 05 2014 B0023932
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 6633083603
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00025.04.14
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002001
ROD: EV_AllWheelContrHA1VW37X_002.rod
VCID: 46D554E3D8226A7B28F-8012
Address 26: Auto Roof (J256) Labels:* None
Part No SW: 8V7 959 255 HW: 8V7 959 255
Component: VSG-AU375 H03 0030
Coding: 400000
ASAM Dataset: EV_ElectRoofContrMAQAU37X 001005
ROD: EV_ElectRoofContrMAQAU37X.rod
VCID: 08499ADB92B6BC0B1A3-805C
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 C HW: 5Q0 959 593 B
Component: TSG FS 020 0026
Serial number: 26051403111326
Coding: 00514E724009040000001402
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 C HW: 5Q0 959 811 C
Component: FOND_FHSG_DRV 002 0005
Serial number: 00000000000002741924
Coding: 0D0000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 3537232FB5C4F1E3B15-8060
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 C HW: 5Q0 959 592 B
Component: TSG BFS 020 0026
Serial number: 26051402091118
Coding: 005146724C09040000001402
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 40D942FBFA06444B123-8014
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 C HW: 5Q0 959 812 C
Component: FOND_FHSG_PSG 002 0005
Serial number: 00000000000002487634
Coding: 150000
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Revision: -------- Serial number: --------------
Coding: 01A600002B230200
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB.rod
VCID: 3FDB410787F83BB36B9-806A
Led Headlamp Powermodule Left:
Subsystem 1 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7530
Coding: E00100
Led Headlamp Powermodule Right:
Subsystem 2 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7530
Coding: E00100
Left Headlamp Power Output Stage:
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7040
Coding: E00100
Right Headlamp Power Output Stage:
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7040
Coding: E00100
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 036 B HW: 8V0 035 036 B
Component: MU-H-LND-EU H43 0356
Serial number: A300E0EB001871
Coding: 017305010000000021111102000A00102F00022701000100DC
ASAM Dataset: EV_MUHig6C3HBAS 001040
ROD: EV_MUHig6C3HBAS_VW48.rod
VCID: 313F173F41ACDDC3EDD-8064
Data medium:
Subsystem 1 - Part No SW: V03 959 800 PS HW: -----------
Component: ECE 2014/2015 --- 0086
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0013
Serial number: AUZ8Z9EY2013ZS
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 R HW: 8V0 919 614 D
Component: ControlUnit_H H64 0766
Serial number: C1000026031400020525
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 1010
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 140515201811
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 7DA7FB0FCD74E9A3395-8028
1 Fault Found:
0006 - Actuator for Structural Accoustics
P193A 00 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 127
Mileage: 52892 km
Date: 2020.11.05
Time: 16:47:51
End----(Elapsed Time: 01:38, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
