Help wipers stopped working!
vw754
vorsprung Durch Technik
U.K
Hi, my s3 2015.
Wipers were working fine and today i was cleaning the car, so i did ignition on, then off and then wiper stalk down once and then put the wipers in 'service mode'........ Now they wont come on, go down or anything, there just stuck.
Ive checked the 30A fuse in the engine bay and that seems fine, i even plugged vcds in..... Doesn't show any codes or anything..... Any ideas??
The obvious first: Ignition on and wiper stalk pushed down.
Failing that have you looked on the mmi, think it's under car settings, check to see if they are on or off in there? I always do mine via the mmi.
Ive done the obvious.
Cant see anything in the mmi
Have you made sure the bonnet is closed, won’t with it open!
Yea, opened and closed bonnet twice, just to make sure.....
heres a scan
Thursday,05,November,2020,18:27:45:22644
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WAUZZZ8V9F10***** License Plate: AUDI S3
Mileage: 52892km-32865mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 26 42 44 52 55 5F A9
VIN: WAUZZZ8V9F10***** Mileage: 52892km-32865miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
26-Auto Roof -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A1D00322426010B2000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ECM20TFS0208V0906259A 001004
ROD: EV_ECM20TFS0208V0906259A.rod
VCID: 3E253C0380F232BB60F-806A
No fault code found.
Readiness: 1010 0001
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H52 4517
Revision: 03252204 Serial number: TFK01405222244
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1F1BE18727385BB34B9-804A
1 Fault Found:
10763 - Starter Enable from Selector Lever Sensor System
P1734 00 [002] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 61484000000769
Coding: 33F193A254232A6C017F070741C769CCC92A5480E08296F6024100F88608
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033.rod
VCID: 45D753EFE5246163215-8010
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 E HW: 8V0 820 043 E
Component: AC Automat H13 0052
Revision: 20000700 Serial number: 00000000318011
Coding: 05100004000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 34311E2BBEBEE8EB86B-8060
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 92F80137000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011414703366
Coding: 07041C47C24106FD03204004B11807A80100000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 005982FBBA86844B523-8054
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 140525 041 0585
Serial number: 140528142132
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22708575
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 G HW: 8V0 941 531 G
Component: E1 - LDS MQB H05 0032
Serial number: 27 03 2014 00000946
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY141050V64
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000029938502
Neck Heating Left:
Subsystem 6 - Part No SW: 8V7 963 579 HW: 8V7 963 579
Component: KRH375 links H14 0003
Serial number: P141562903702000159
Neck Heating Right:
Subsystem 7 - Part No SW: 8V7 963 579 HW: 8V7 963 579
Component: KRH375 rechts H14 0003
Serial number: P141562903702000158
1 Fault Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [008] - Electrical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 3
Reset counter: 167
Mileage: 52892 km
Date: 2020.11.05
Time: 17:29:09
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 E HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0051
Revision: -------- Serial number: 39231415700035
Coding: 0000050011
ASAM Dataset: EV_EPHVA14AU3700000 002022
ROD: EV_EPHVA14AU3700000_002_VW37.rod
VCID: 3B23351793E02793471-806E
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 C HW: 8V0 907 376 C
Component: DAEMPFUNGS-SG H08 0066
Serial number: 290514002
ASAM Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide.rod
VCID: 41DF47FFF10C4D431DD-8014
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 A HW: 5Q0 959 655 A
Component: AirbagVW20 009 0865
Serial number: 003ESR0098VY
Coding: 98C0C0000000A0005C5000CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002136
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 000 206 14
Component: SideSensor_Df 001 0887
Serial number: 3570000000098AA4CF0/
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 000 206 14
Component: SideSensor_Pf 001 0887
Serial number: 358000000008CAA4CF01
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 012 705 14
Component: SideSensor_Dr 004 0108
Serial number: 351001A01BF11ED23DBJ
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 4 - Part No SW: ----------- HW: 480 400 804 14
Component: FrontSensor_D 001 6149
Serial number: 35500029B1524DC3111Z
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 CB HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 06061404220247
Coding: A018
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 7CA1F60BD66EE0AB0EB-8028
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 971 J HW: 8V0 920 971 J
Component: KOMBI H02 4291
Coding: 27AD100A3B8026000101E8001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009040
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 44D14EEBEE1E586B36B-8010
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 28051410800736
Coding: 030100042F085A005B0002689C0B00000001010000000000000000000000
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_011.rod
VCID: 42DD48F3F40A565B047-8016
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 26 05 2014 B0023932
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 6633083603
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00025.04.14
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002001
ROD: EV_AllWheelContrHA1VW37X_002.rod
VCID: 46D554E3D8226A7B28F-8012
Address 26: Auto Roof (J256) Labels:* None
Part No SW: 8V7 959 255 HW: 8V7 959 255
Component: VSG-AU375 H03 0030
Coding: 400000
ASAM Dataset: EV_ElectRoofContrMAQAU37X 001005
ROD: EV_ElectRoofContrMAQAU37X.rod
VCID: 08499ADB92B6BC0B1A3-805C
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 C HW: 5Q0 959 593 B
Component: TSG FS 020 0026
Serial number: 26051403111326
Coding: 00514E724009040000001402
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 C HW: 5Q0 959 811 C
Component: FOND_FHSG_DRV 002 0005
Serial number: 00000000000002741924
Coding: 0D0000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 3537232FB5C4F1E3B15-8060
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 C HW: 5Q0 959 592 B
Component: TSG BFS 020 0026
Serial number: 26051402091118
Coding: 005146724C09040000001402
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 40D942FBFA06444B123-8014
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 C HW: 5Q0 959 812 C
Component: FOND_FHSG_PSG 002 0005
Serial number: 00000000000002487634
Coding: 150000
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Revision: -------- Serial number: --------------
Coding: 01A600002B230200
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB.rod
VCID: 3FDB410787F83BB36B9-806A
Led Headlamp Powermodule Left:
Subsystem 1 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7530
Coding: E00100
Led Headlamp Powermodule Right:
Subsystem 2 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7530
Coding: E00100
Left Headlamp Power Output Stage:
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7040
Coding: E00100
Right Headlamp Power Output Stage:
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7040
Coding: E00100
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 036 B HW: 8V0 035 036 B
Component: MU-H-LND-EU H43 0356
Serial number: A300E0EB001871
Coding: 017305010000000021111102000A00102F00022701000100DC
ASAM Dataset: EV_MUHig6C3HBAS 001040
ROD: EV_MUHig6C3HBAS_VW48.rod
VCID: 313F173F41ACDDC3EDD-8064
Data medium:
Subsystem 1 - Part No SW: V03 959 800 PS HW: -----------
Component: ECE 2014/2015 --- 0086
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0013
Serial number: AUZ8Z9EY2013ZS
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 R HW: 8V0 919 614 D
Component: ControlUnit_H H64 0766
Serial number: C1000026031400020525
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 1010
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 140515201811
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 7DA7FB0FCD74E9A3395-8028
1 Fault Found:
0006 - Actuator for Structural Accoustics
P193A 00 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 127
Mileage: 52892 km
Date: 2020.11.05
Time: 16:47:51
End----(Elapsed Time: 01:38, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
763
S
654
SuperflyTNT1974
S
37
29K
