I have a 2007 2.0 PD170. I've had the car for about 10yrs and it's been on the whole very reliable and also well looked after/serviced. However I have an issue that came on suddenly that I can't figure out; there is no power from around 1800rpm to around 2300rpm, after which where it starts to pick up and run kind of normally (maybe at around 80% power). Below 1800rpm it drives normally, perhaps a little down on normal power.
From 1800rpm I can have my foot flat to the floor and it does nothing at all, just stays at the same revs, except in 1st and 2nd gear where I can get it to "drive through" this deadzone and it starts to pick up. On VCDS it shows around 90nm torque (actual), even though with foot to floor driver request is 430nm.
Say in 3rd going up a hill, at 2000rpm it starts to judder and slow down. If I drop down in to 2nd to ensure revs around 2500rpm it will accelerate.
It idles perfectly smoothly, mpg is normal (ie great), there are no unusual noises.
VCDS show a very non-specific fault code:
1 Fault Found:
000000 - SAE - Reserved by Document ISO 15031-6
P0000 - 006 - 2005
Freeze frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 395227km
Time Indication: 0
Date: 2021.01.22
Time: 16:02:46
I read a thread a while back about a 170 with similar issue but can't find it!
1 Fault Found:
P0000 - 006 - 2005
Freeze frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 395227km
Time Indication: 0
Date: 2021.01.22
Time: 16:02:46
