yeah checked it multiple times.Maf plugged in all okay ?
based on this picture maybe my catch can in plugged in the wrong way? is that even a thing can it not be plugged in either way? hmm
That was a pic I sent to mph before fitting it all together to show the pipes. It all connected now however. New braided fuel lines on tomorow. Adapters should be coming for my pirsche twists in the morning. And hopefully be able to take the car for a drive for the 1st time this yearYour catch can in piped in the wrong way round, inlet is left hand side and outlet is right hand side. Also Asim appears to be venting to atmosphere, which you don’t want to do running on a standard Ecu unless mapped for it.
Also check your hockey puck is the right way round as it’s basically a none return valve.
Check where you’ve connected your pipe into the crankcase breather as these plastic elbows are prone to break with the slightest touch.
