Victoria81
Hello, looking for a bit of help. Driving Audi A5 today when EPC light came on and message "stabilisation control fault". Couldn't accelerate and had to pull in. Called AA out and they plugged it in. Engine control 1 - VS2 / Simos 12 UDSP00B700 - Coolant temperature regulation. Error Message : Inadequate effect.P064200 - Sensor reference voltage A. Error Message : Signal too low.P063800 - Throttle valve (TV) control unit. Error Message : Signal improbable.P138800 - Control unit. Error Message : Component defective.P168000 - Reset-resistant emergency operation. Error Message : Component/function active.P256300 - Charge pressure actuator position sensor. Error Message : Signal improbable.P226300 - Turbocharger. Error Message : Faulty operation.P060600 - Control unit. Error Message : Component defective.P012200 - Throttle-valve position sensor. Error Message : Signal too low.P022200 - Throttle valve position sensor 2. Error Message : Signal too low.U044700 - Gateway. Error Message : Signal improbable.P004500 - Boost pressure control (bank 1). Error Message : Open circuit. Suspect throttle position sensor. Cut out non start. No response. from pedal in live data. Had to be towed home and have no idea how much this is going to cost?!
