ABS tab repair which method to use?
aqibi2000
Looking for advise for tried and tested tab repair for ABS:
-JB Plasticweld remains flexible
-Araldite epoxy chips off easily
want something that stays solid and actually adheres to the ABS, 4 tabs abs various ABS bits to fix
Topfix 2 pack is what I use for clients, expensive but brilliant.
Thanks for that, saw it has good reviews although a bit expensive for me since I mainly work on my own or family cars :/
I tend to use a hot stapler and then reinforce with fibreglass for larger tabs, otherwise I try to plastic weld smaller tabs. Works fine on bikes.
Headlight mounting tabs are what I want to fix and also a small split in the lower portion of a bumper.
I’ve been trawling google too and not much info there (doesn’t have to be A3 specific)
Headlight mounts are replaceable from audi, top & side, you cut old one of & screw new one in place, I then reinforce with topfix.
