I have an Audi S3 8V which has had a bad idle for some time. It has never stalled, but it idles quite lumpy at times (not always) especially when cold. I had a mechanic look it and promptly replace the timing chain (thought it could have stretched) and the issue still persists. The mechanic is at a loss as to what to do next and frankly I have lost confidence in them. I'm going to have a crack at fixing this myself.
The code I am seeing is a P0014 - Bank 1: Camshaft B (Exhaust). Re-tard Setpoint not Reached (Over-Advanced).
It's also throwing a P0017 - Engine Speed Sensor. Incorrect correlation.
After doing quite a lot of research and buying the manuals, I'm thinking of replacing:
1) Exhaust camshaft adjuster magnet
2) Camshaft adjuster oil control valve (n318) - (I assume this is the same part as n205?)
3) Testing and possibly replacing any problematic VVT Solenoid (Cam adjustment actuator).
Is it possible to test the VVT solenoids with VCDS? I would rather test them in situ than remove them and manually apply 12v. VCDS would be preferable. Any ideas? Am I on the right track here??
