Took my Audi A6 Avant 2019 into Audi dealership to day to fix why i couldn't connect apple carplay wirelessly - They informed me is that my model runs MMI MIB2+ which is only be set to USB connect only. Is this true or can it be retro switched to connect wirelessly, if so how do I go about setting this?Wireless Carplay can be activated also on MIB2 (VCDS/OBD11).
My 2019y a6 c8 supports wireless carplay, android is cable only. I just enabled it with obd11.
If it gives anything, I got MMI Plus with Large 10,1 inch screen
If you have the Tech pack option then it is possible to have the screen display map plus phone and media selection all on the one screen (you swipe right on the Home Screen). If you have the standard system then you do not get that facility regardless of whether it is MIB-2 or MIB-3My Dec 2018 A6 has the home screen with the "tile buttons" for navigation, phone etc. I've noticed on newer vehicles there is another screen with 3 "widgets", anyone got any info on the functionality these offer?
I have the Tech pack, but not this extra screen. Not sure if it's a software update or the newer MIB that has it?If you have the Tech pack option then it is possible to have the screen display map plus phone and media selection all on the one screen (you swipe right on the Home Screen). If you have the standard system then you do not get that facility regardless of whether it is MIB-2 or MIB-3
Been on the email and Kufatec but found them very unhelpfull. I screen shot them my software version but they did not answer me if this will for my car.MIB2 and MIB2P (plus) are very different units. Don’t confuse the two. Plus can do wireless if the firmware version is correct and all is coded as needed.
Sound. Are you allowed to tell me his name here or no ? That kufatec think is only £100 but just could not get the answer from themWireless CarPlay is possible. You have a coding partner in Leicester that can do this for you:
VAGPro
Sound. Are you allowed to tell me his name here or no ? That kufatec think is only £100 but just could notWireless CarPlay is possible. You have a coding partner in Leicester that can do this for you:
VAGPro
tha ks I send txt message but from the number from google is the number also active ? Thanks
Call me old fashioned but it might be an idea to actually give VAGPro a call. It’s also the Xmas eve so I would not be expecting a reply until businesses return to work.
Where did I said I need answer today ? I also said in my message let me know once back at work after Christmas don’t panicShocking eh Alex, how dare someone not respond right away at Christmas
lets see your rear lights in action ?Just come back from the lad all sorted, he also change my light animation to RS mode
Happy customer
Thanks for help
Nah mate. The standard show is one think and the rs mode show is a bit different. With HD matrix you have the quick light show as standard but the RS mode is deactivated by Audiyou should have it mate as standard yours are the same as mine turn on coming home /leaving home and lock the car!
There are two different animation mate. Standard one - only available when tou have the hd matrix lights and RS mode what you can activate.mines active as standard its called animation in vcds doesn't mention rs! says headlight /taillight animation
