I thgink I have the not uncommon problem of gear selection on manual box. Can select gears if engine off. With engine running cannot select any. CAn select 1st with engine off then start and will move but unable to select other gears. Done fair bit of reading but none the wiser. Suggestions are slave cylinder, master cylinder of problem inside clutch.
Been suggested bleed clutch, I would if I knew how. Help.
