Help!! S3 Washer bottle leaking!!
Pastry
Romford
Hi all,
I've read that this is quite a common thing, but not seen a thread on it recently. My S3 (67 reg fl) decided to dump some water on the driveway a couple of weeks ago (and the light came on) since then it has dropped slightly, but not by much. I put a tray under the car to see what came out, about half a cup worth over night. The filter is clean & I have filled it between the two corrugated parts of the pipe so I can see where the level is. I carry a bottle of coolant to top it up when necessary.
How hard is this to fix ? (what actually fails ? ) How long does it take to fix ? What sort of cost is involved ?
Thanks in advance.
So is it washer fluid or coolant leaking? You mention both.
Mine was leaking at the headlight washer on the bumper not long after I got mine. Worth checking there
