My windscreen washer pump worked one day and then nothing the next, the headlight washer pump still works so I know its not the fuse as the windscreen pump and headlight pump work off the same fuse but the windscreen washer pump is just silent, nothing there, anything you guys think it could be or is it just a case of its broke? It was left empty for a couple of weeks as I just kept forgetting to top up the fluid, then when I did top it up, I tried to wash the screen and nothing happened but it worked fine before that, I was thinking maybe it has some sort of level sensor? I don't want to spend £100's getting it fixed if it could be a simpler thing.
