Rattle from seat undertray
Gmac
Aberdeenshire
Morning folks!
Got an annoying rattle from the tray that pulls out from under the passenger seat. Anyone else found a good solution to stop the problem? I’m thinking just put something heavy in there, but not ideal. Lol
is it the full size tray or just the short drop-down door one?
To test, put some cardboard between the door & box, shut & see if it stops, then if so add some foam sticky pads between the 2 pieces.
Reactions: Charlie Farley
I used a bit of blue tack , it works wonders on squeaks and rattles.:icon thumright:
Reactions: Gmac
I think you’re thinking of the glove box? I’m talking about the tray under the seat:thumbs up:
sounds like the ones fitted to my Recaro's, from memory they can be removed and the fittings all tightened up, i had a similar issue.
Reactions: Gmac
this is the underside of the draw frame you can see the draw runners, sometimes bits get loose and just rattle .
1678569313819
Reactions: Gmac
