Audi A7 Start/Stop system fault / Function unavailable
Gaby85
Doncaster
Hi, I have Audi A7
Today I drive the car around 30 miles I lefted in the garage…after 2/3 hours wen I wanted to go
And i got this message on my dashboard.
What can be the problem?
Any help please, thank you
How long has it been sat for?
Might be worth checking your battery and whether it is depleted/heading that way
Reactions: Gaby85
After 2/3 hours I wanted to use again
Obviously the car is starting without problems, just that the engine marker is on and the error start-stop system fault function unavailable
Thank you
Ideally you need to get the car scanned to see if there is more information logged.
Reason I mentioned battery is I had this issue with my A7 back in the day and it was indeed the battery
The Start/Stop function monitors various car parameters, before deciding if start/stop function is available.
this includes:
  • Battery cranking voltage
  • Engine temperature
  • Cooling fan operation
  • Battery load, including lights, aircon, MMI, heated seats etc.
  • Ambient air temperature
  • Alternator charging voltage
A failure in any one of these will prevent start/stop operation for safety reasons.
if start/stop in not available following a period of parking, then your battery voltage is too low. This is caused by an aged battery bit holding its charge, or the alternator is not delivering a full charge.
How old is your car, has the battery been replaced (and coded) in the last 3 years?
if car is over 5/6 years old, I’d start by either replacing the battery, or getting the car scanned for fault codes.
John :hi:
Stop Strain is ment to save you £ except it doesn't it costs money to get it to function properly and the earlier wearing of certain components , best not to have it working .
